cossie ARB and compression strut
Old Aug 10, 2008 | 03:56 AM
coachworz's Avatar
coachworz
Default cossie ARB and compression strut
hi, can i have both together?
Old Oct 13, 2008 | 12:34 AM
stage 3 muppet's Avatar
stage 3 muppet
yes you can have a setup myself that still uses the arb ..
much better than doing away with arb and using struts on there own imho
Old Oct 13, 2008 | 12:45 AM
sortedsaff's Avatar
sortedsaff
any pics of the arb+comp strut set up
Old Oct 13, 2008 | 12:49 AM
Azrael's Avatar
Azrael
+ any info where to get bits for such setup?
Old Oct 14, 2008 | 01:10 AM
stage 3 muppet
yes pics below hope they help somewhat lol
whole setup has been made up to be as adjustable as possible even inc actual arb end float movement so to say ,has threaded part on the end to adjust to suit bottom arm position
quite happy with the setup to be honest
pics below cheers
also worth noting whole comp strut setup bolts to original arb mount holes ,with the arb sitting on top piggyback style held in by original brackets.. but will also be welded in to help eliminate any flexing
overview as in car
http://i157.photobucket.com/albums/t...7/DSCN2609.jpg
couple of drop links and arb attaching point
can also see arb adjustment on the very end if you look closely
http://i157.photobucket.com/albums/t...7/DSCN2614.jpg
http://i157.photobucket.com/albums/t...7/DSCN2613.jpg
http://i157.photobucket.com/albums/t...7/DSCN2612.jpg
http://i157.photobucket.com/albums/t...7/DSCN2611.jpg
Old Oct 14, 2008 | 01:20 AM
coachworz's Avatar
coachworz
where can i get the conversion parts?
Old Oct 14, 2008 | 01:25 AM
stage 3 muppet
the compression struts can be bought from lots of cosworth specialists
and the rest is just creative ingenuity and trial and error
not sure if anywhere sells kits like this complete or not ??? but have seen a few diff methods of acheiving the same results as this
try googling it im sure you will find something
the comp struts can be bought from the likes of compbrake
hope this helps
Old Oct 14, 2008 | 03:40 PM
coachworz's Avatar
coachworz
i am not good at DIY .... would be great if i can buy it complete saving me all the hassle....
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Fezman1
Oct 2, 2015 01:22 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
