how the hells this come off
Old Nov 1, 2004 | 01:05 PM
K500BHP's Avatar
K500BHP
Default how the hells this come off
how the hell do i getthe plastic fuel line from the metal fuel line to the injector rail off?????
do i need the tool in the manual or is there an idiots guide to doing it that i can't see
Old Nov 1, 2004 | 01:50 PM
A.Moore's Avatar
A.Moore
Jim don't remove it there! Remove the whole fuel rail, unless that is the pipe you are changing?
The fuel rail is secured by x2 10mm head bolts, remove x4 clips at the top of each injector then the rail lifts off.Beware of pressurised fuel spraying out though.Al.
Old Nov 1, 2004 | 04:33 PM
K500BHP's Avatar
K500BHP
unfortunatly thats the pipe i have to change and iv'e just found out the 2wd one is obselite and the 4x4 one is totaly different
Old Nov 1, 2004 | 04:46 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Jim, I used a bit of stout wire (fencing wire IIRC) which I bent into a U and L shape if you see what I mean, L shape viewed from the side, U from above
There are two little holes on the side of the plastic connector, push the UL thingy in those holes while you pull gently on the plastic pipe - I should all come off.
Good luck and be gentle but firm.
Old Nov 1, 2004 | 04:50 PM
jayRS's Avatar
jayRS
relieve the fuel pressure by taking the fuse out to the fuel pump and turn it over, also take the filler cap off to take pressure out of the tank.
dunno if you need to do both but that what it says in the book
K500BHP's Avatar
K500BHP
cheeRS m8 wish me luck
Old Nov 1, 2004 | 04:53 PM
jayRS's Avatar
jayRS
your be ok, just dont smoke whilt doing it lol
deathrider666
Sep 28, 2015 06:12 PM
3doorcozmess
Sep 20, 2015 06:15 PM
Fraggle...
Aug 28, 2015 06:29 PM
