sierra abs problem
Old Jun 27, 2008 | 03:39 PM
whitesaff91's Avatar
whitesaff91
Default sierra abs problem
hi there, i'm new to this, my sierra is not a real cosworth but a 2 litre dohc so as far as i know has the same abs system. the abs light on the dash goes out almost immediatly when the engine is started, but it comes on when you go over 10mph. ive checked the sensors and they all read between 1050-1100 ohms. i have also noticed there is no abs relay in the fusebox where the manual says there should be one. any suggestions?
any help would be greatly appreciated,
peter
heres a pic of it, my recently finished replica. i'm only 17 so a real one was never an option.
Old Jun 28, 2008 | 05:18 AM
velocity's Avatar
velocity
Wink
i,ll have a look at wireing the wire diagrams, your abs is practically the same as a cozzy,
where is the relay thats missing and we,ll see if we can sort it out.
Old Jun 28, 2008 | 06:12 AM
rickbartlett's Avatar
rickbartlett
G911 TTA
nice tidy rep mate
Old Jun 28, 2008 | 11:45 AM
whitesaff91
in the fusebox beside the wiper motor, vii is written beside it and the handbook says that there should be an abs relay there
Old Jun 29, 2008 | 09:07 PM
velocity's Avatar
velocity
Thumbs up
the relay VII in the fuse box is for the 4x4 sapphire cosworth only, the standard sierra pre 89 used it but had a different arangement.
the standard sapphire 1990 on has all its abs relays on the (M) relay module which is located under the dash at the r/h side of the passenger footwell around the lower corner of the glove box. it can be lowered down by undoing a screw/bolt for easier access.
relay m12 is the main abs relay, m13 in the abs pump relay 1
and m14 is abs pump relay2,
fuses 30,31,34 supply the 3 relays with main power, the relays are activated via the earthing through the abs computer.
with your problem the fact that the light is going out and then comming back on when you drive would indicate a speed sencing failure to me and that means sensors or sensor.
the do fail completly or can be intermittant.
fuse or relay failure will generally have the light on permanent and or the break pedal very hard.
you could check for continuity between pins 22,23,24,25 at the abs computer and their respective sensors, if thats ok then i would replace the front two sensors regardless of ohms readings, if that fails then replace the back two,it is expensive but it may be the only way to sort it as the system is generally reliable except for the sensors.
let me know how you get on
Old Jun 29, 2008 | 10:04 PM
whitesaff91
hi velocity, i have checked the AC voltage of each sensor at the connect while rotating the wheel at 1 revolution per second. the voltmeter we have has a 2 vac setting. the rear sensors read 0.1 vac each. the front left sensor was 0.03 vac. the front right sensor had no output. we changed the front right sensor and the output of this sensor was 0.02 vac. the light now stays out. when you are comin to a stop there is a small rattlin noise from the abs. we will buy 2 second hand sensors to replace the ones with low readings, and hopefully this will fix it fully.
thanks to everyone for their comments and suggestions on fixing the abs, peter
Old Jun 30, 2008 | 12:22 AM
velocity's Avatar
velocity
Talking
glad to see your 99% there.good work
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
robbo9006
11
Sep 1, 2015 02:10 PM
andyrs1600i
Aug 30, 2015 07:21 PM
Vincereese
Aug 15, 2015 06:24 PM
Vincereese
Aug 11, 2015 08:44 AM
