Where to get caliper piston
Old Jun 12, 2008 | 09:50 AM
javierant3's Avatar
javierant3
Default Where to get caliper piston
Hello , recently I have bought a pair of calipers from a S2 turbo, but I found that the piston on one of the calipers is rusty. I need new pistons, and repair kit for that caliper.
The piston is 60mm diameter.
Where can I buy the pistons and kits? I am in Spain, but here there aren`t that pieces.
Old Jun 12, 2008 | 10:13 AM
JesseT's Avatar
JesseT
Any ford 60mm caliper piston will fit, they are all the same. Try to find one for a Scorpio.
Old Jun 12, 2008 | 12:35 PM
bpspa's Avatar
bpspa
failing the above contact http://www.biggred.co.uk/
Old Jun 12, 2008 | 06:48 PM
fonfe's Avatar
fonfe
or just buy any mk4 ecort calipers from a local motor parts shop as all mk4 calipers are the same it is the caliper carrier not the actual caliper that is different on the s2 turbo which allows the use for slightly bigger discs
Old Jun 12, 2008 | 08:22 PM
JesseT's Avatar
JesseT
Not true! All other mk4's use the smaller 54mm pistons in the calipers for except the RS turbo.
Old Jun 13, 2008 | 05:06 PM
fonfe's Avatar
fonfe
i stand corrected then!
my apologies
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
deathrider666
Sep 28, 2015 06:12 PM
Sp3no
Sep 27, 2015 07:23 PM
IainRS1700T
Sep 25, 2015 06:44 AM
