Upgrading Injectors
That wasn't really where I was coming from. A couple of points:
1) By 'yellow injectors' I assume you mean std cossie? Well they're low-impedence and will eat your ECU alive.
2) The fuelling would be completely wrong, and the chip may not be calibrated at the higher boost levels you want to run, so who knows what'd happen.
3) Chip may have a boost cut in it anyway to stop you going any higher.
i will buy your bieges though
you csan upgrade to the next injectors from bieges and they are light greens not cossie jobbies they are the next step up from bieges dont have the part number but there is a thread i started about it
nowe sell us the bieges!!
Cheers pal i think ill stick to the beige's till i upgrade!
mk3ste
Oct 17, 2021 10:09 AM
