compression escort turbo
Old Oct 26, 2004 | 02:04 PM
nacnac's Avatar
nacnac
Default compression escort turbo
what should the compression of a standard engine read on the compression tester you screw into the spark plug holes.
in psi or bar.
thanxs nick
Old Oct 26, 2004 | 06:31 PM
sammy's Avatar
sammy
genarally, you should be looking for a simlar reading on each cylinder, if you have an odd 1 (or 2), you have a problem! not to sure what the readings are normaly, i would expect around 120 psi up,(although i have a nissan turbo which read 180 psi)
Old Oct 27, 2004 | 09:19 AM
JesseT's Avatar
JesseT
I had 9.5bar with a wild cam in a S1 engine with standard C/R, so ~10bar for a standard cam.
Vincereese
Jun 1, 2023 09:14 AM
Matt Baxter
Sep 16, 2015 08:30 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
druidgetafix
Aug 15, 2015 10:22 AM
