negative camber on 1 side??
Old Feb 15, 2008 | 01:07 PM
RS16iDale's Avatar
RS16iDale
Default negative camber on 1 side??
ok the other nite i change both the shock and the lower arm on the passenger side of my mk3 rs1800,but when i went to drive it the steering wheel is way off straight and it pulls to the left.also wen you are parked and the wheels are straight the passenger side has negative camber and seems slighty turnt??
so i thought that may be it was because the shocks on either side were odd so i changed the shock and lower arm on the drviers side but its still the same
ive checked everything i can think of so any help would be good
cheers Dale
Old Feb 15, 2008 | 01:24 PM
zetecapri's Avatar
zetecapri
2.0 16v Turbo
might have wasted your money doing the other side, get it wheel aligned, should only be about 40 quid
Old Feb 15, 2008 | 01:51 PM
RS16iDale's Avatar
RS16iDale
im thinking that may have got the wrong lower arm??
Old Feb 15, 2008 | 02:43 PM
zetecapri's Avatar
zetecapri
2.0 16v Turbo
well the pulling will be down to the toe, and even though camber is non adjustable, adjusting the toe does change it a little, personally id go for wheel alignment.
gcfcos
59
Oct 6, 2015 05:04 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Shaunc
Escort Range
Sep 22, 2015 06:38 PM
