Broken Horn, Mk6 Escort
Old Dec 6, 2007 | 06:17 PM
rbwilling's Avatar
rbwilling
Default Broken Horn, Mk6 Escort
Horn has stopped working in the car for one reason or another.
I've checked the fuse (number 28 i think!) and thats fine.
Whats the best thing to check or do, as obviously im not too mechanically minded and am wary of the airbag. Could it be a wiring problem or could the actual horn have broken??
The car has only done 70,000 miles and everything is in good condition. Have never known of a horn to break before!?
Any help appreciated
Old Dec 6, 2007 | 06:46 PM
It's a lot more likely to be the horn that is duff, some have a screw that can be adjusted to tune back in.
Check with a test light at the hron to see if you are getting live and earth, if you are then the horn is duff.
Old Dec 7, 2007 | 07:47 AM
rbwilling's Avatar
rbwilling
Thanks
rex647
Mar 6, 2022 06:20 AM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
