puma injector flow rates?
Old Nov 23, 2007 | 09:42 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
Default puma injector flow rates?
does anyone know the above, and what max bhp they fuel for?
i should soon be getting a FRP exhaust system and 4-2-1 manifold, piper FRP spec cams and im gonna make some bike throttle bodies fit it too
but i need to know what the max bhp the std injectors can flow as they are gay side fed efforts...
ta
Old Nov 23, 2007 | 09:50 AM
wide ka's Avatar
wide ka
if you are using throttle bodies then why not use the injectors in those? im got a focus 1.6 and the injectors would not flow enough fuel for mine, and im running cams headwork and throttle bodies so i used the bike ones insted and they are fine, are the puma ones in the head or on the inlet?
Old Nov 23, 2007 | 10:03 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
puma ones are in the head mate, im pretty sure they will be ok as the thing wont see any more than around 170bhp tops i reckon
pretty sure they use the same injectors ont he FRP and they are 150bhp out the box
i need to use the holes in the tb's where the bike injectors go for the brake servo vac
Old Nov 23, 2007 | 10:42 PM
wide ka's Avatar
wide ka
i see, if they are the same as frp ones then should be fine i would think, carnt you tee into the inlet for the servo thats what i did with mine, if you do that i know where you can get some blanking plugs for the head where the ford injectors used to sit
Old Nov 23, 2007 | 10:59 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
it wont have an inlet mate if i rub tb's, it will need a vac take off from each cylinder and the injector holes are ideal
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
youngben
Sep 27, 2015 09:37 PM
Marv888
Sep 26, 2015 03:44 PM
