Head work
Old Nov 15, 2007 | 05:32 PM
Billy_RS's Avatar
Billy_RS
Default Head work
Where is the place to have head work done.
CVH EFi head.
Thinking of using a Newmans cam, solid lifters. I'm just not too sure about what to have done with valves and porting etc...
This will be the head for my 2.1 ZVH engine build.
Thanks in advance
Billy
Old Nov 15, 2007 | 06:03 PM
Billy_RS's Avatar
Billy_RS
Answers on a postcard please
Old Nov 15, 2007 | 06:29 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
depends what ur wanting to spend billy mate ?
but puma racing do a 45mm big vale head for around 800 nicker
thats the best there is and whats going on mine
Old Nov 15, 2007 | 06:46 PM
GARETH T's Avatar
GARETH T
KARL NORRIS
Old Nov 15, 2007 | 07:08 PM
Twellsie's Avatar
Twellsie
Originally Posted by GARETH T
KARL NORRIS
Old Nov 15, 2007 | 07:26 PM
bigchez's Avatar
bigchez
CNC heads, vulcan or cylinder head developments.
Old Nov 15, 2007 | 07:58 PM
Nick-T's Avatar
Nick-T
Give Jamie at JamSport a shout on 01604 755529.
His CVH heads are awesome, I run one and can't fault it at all. Jamie is also a Newman dealer so can advise on cam profiles etc as well..
Old Nov 15, 2007 | 08:53 PM
Billy_RS's Avatar
Billy_RS
Thats good then seeing as i already bought go-tech from him.
I'll give him a bell and see what can be done, thanks.
Old Nov 16, 2007 | 07:02 AM
Badman38's Avatar
Badman38
pumaracing 45mm valve head which i am currently running to make the cvh head work well with the 2.0 upwards zetec bottomend, you really need huge valve area and big ports to get as much air in there as possible,
A head which might not work well with a 1.6cvh unless you ran steel rods and was able to rev beyond 7000rpm this head will work well with the bigger bore bottomend..
thanks
sean
Old Nov 16, 2007 | 09:14 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Jamie and Karl both have excellent reputations for the CVH, so well worth trying them, and if you have gotech anyway then Jamie sounds the logical choice.
3i Jim
Nov 20, 2015 05:12 AM
salsheikh
Alloy wheels and ICE for sale
Aug 20, 2015 12:33 PM
salsheikh
Jul 30, 2015 08:45 PM
