bosch 403 grey fitting help
Old Aug 21, 2007 | 10:03 PM
garyrs's Avatar
garyrs
Default bosch 403 grey fitting help
hi i am after some advice for a friend ,he is trying to fit a set of brand new greys into a cossie fuel rail , he phoned woodford garage who told him they will have to be flow tested and the fitting kit would need to be pressed on ? has anny of you guys or girls fitted grays your self ? if so some pictures of the fitting order of the plastic and metal rings would be fandabidoozle , he also dont no what to do with the blue plastic thing that is on the spray side ( i dont mean the dust cover lol) , he is pulling his hair out so anny advice would be very welcome
thanks
gary
Old Aug 22, 2007 | 02:00 PM
2001ode's Avatar
2001ode
Hi,
That is Ford Motor Sport indications.
Regards.
Claude
Old Aug 23, 2007 | 06:45 AM
garyrs's Avatar
garyrs
thank you claude very helpful
Old Aug 26, 2007 | 10:10 PM
costina's Avatar
costina
Live long and prosper!!
DO NOT use the cap on the end in std form it needs to be drilled 7mm or cut off or not used at all
Paul
Old Aug 27, 2007 | 06:25 AM
2001ode's Avatar
2001ode
Paul
Hi Paul,
Why exactly ?
Thanks
Claude
Old Aug 27, 2007 | 09:08 AM
costina's Avatar
costina
Because the cap is not designed for that injector and messes with the spray pattern,hence drilling the cap or removing it.
I've removed my caps
They can cause fueling issues and melted pistons(with the cap on)
Do a search on here theres a more indepth answer
Paul
Old Aug 27, 2007 | 09:17 AM
costina's Avatar
costina
https://passionford.com/forum/viewto...asc&highlight=
Read this
Paul
Old Aug 27, 2007 | 03:13 PM
2001ode's Avatar
2001ode
https://passionford.com/forum/viewtopic.php?t=211417&start=0&postdays=0&postorde r=asc&highlight=
Read this
Paul
Thanks Paul.
To morrow, I know what to do.
Many thanks.
Claude
Old Aug 27, 2007 | 09:31 PM
garyrs's Avatar
garyrs
cheers guys ,anny tips on how to get the metal rings on the fuel rail side (top) i mean do i just lube it up ,put it in a vice and wack it on with a socket ??? or what
Old Aug 27, 2007 | 10:16 PM
costina's Avatar
costina
I used a socket and a vice
Fairly simple
Paul
Old Aug 27, 2007 | 11:54 PM
garyrs's Avatar
garyrs
thanks paul ,will give it a blast
manuel boeckx
13
Oct 3, 2015 02:29 PM
ekjim
Aug 27, 2015 05:20 PM
john_3.0s
Aug 16, 2015 06:40 PM
CrOwSoN15
Aug 14, 2015 06:52 PM
MadsBL
Wheels and Tyres
Aug 6, 2015 10:04 AM
