zvh conversion..
Old Aug 2, 2007 | 11:51 PM
ram's Avatar
ram
Has a large member
Default zvh conversion..
anyone know of any good online guides for doing a zvh conversion? im putting a 1.8 zetec bottom end on my cvh.
cheers.
Old Aug 3, 2007 | 01:01 AM
fast_4door's Avatar
fast_4door
www.jimhearne.co.uk
www.zetecinside.com
these sites are good from what i can tell ps think the 1.8 is alot easier than 2.0 cause you won't need to change much. as far as i can see you need mounts due to oil filter you can buy them from retro ford website, need to plug holes in block and skim and either decomp plate or skim pistons, i'd look into that abit more though before making a choice of what to do ie how thicker plate or how much skimed??
Old Aug 3, 2007 | 02:48 AM
fast_4door's Avatar
fast_4door
ZVH Engines. The "ZVH" engine is a Ford Zetec bottom end (1.8 or 2.0 litre) with a Ford CVH head fitted. To fit the head to the block there are 3 problems to overcome - 1) Compression ratio. 2) The redundant oil return passages in the Zetec block that need to be blanked off. 3) There is a waterway in the Zetec block that sits very close to an oil gallery in the CVH head.
A copper decompression plate will tackle all of these 3 problems in one go (assuming this is a turbo engine), and will allow easy fitment of block to head. If you have already sorted out issues 2 & 3, then a (cheaper) alloy plate can be used.
found @ http://www.ferriday.co.uk
Old Aug 3, 2007 | 10:27 AM
ram's Avatar
ram
Has a large member
cheers mate. anyone got any more?
mk1turboestate
Dec 2, 2015 08:31 PM
Chas
Oct 5, 2015 07:13 PM
davidfordrs
Sep 23, 2015 02:26 PM
davidfordrs
Sep 21, 2015 04:23 AM
Del gsxr
Sep 19, 2015 05:53 PM
