xr3i boiling over
Old Aug 2, 2007 | 12:19 AM
Grandad racer's Avatar
Grandad racer
Default xr3i boiling over
as above, this is my xr3i project on the road at last!! been off the road for 5 yrs, not sorned!! no sutch thing when this 3i was last used! did one mile and boiled over, but the radiator is cold, how can i tell if its the water pump ,or the thermostat??
Old Aug 2, 2007 | 04:08 AM
rs_cabby's Avatar
rs_cabby
waterpump normally gets noisy, check the waterpump pulley
for any unusual movement.
As for the thermostat, take it out, run it up
and see if the same problem occurs.
Old Aug 2, 2007 | 05:25 AM
bluescortcossie's Avatar
bluescortcossie
probably your thermostat has rusted up in the closed position , like said above take it out completely and let it run up to operating temp , the rad should then get warm and not boil over , if that's the case replace the thermostat and job done
Old Aug 2, 2007 | 06:21 AM
It would be wise to change the stat anyway, and is the most likely suspect.
Old Aug 2, 2007 | 10:30 AM
Grandad racer
cheers guys, thanks for the quick repliys!!!
Old Aug 2, 2007 | 10:51 AM
bluescortcossie
another point to make too -
while you are at back flush the whole system and get all the crap out
stephenb4506
33
Oct 2, 2015 06:25 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
