indicators not working
Old Jul 26, 2007 | 03:19 PM
zvhturbo29rs's Avatar
zvhturbo29rs
Default indicators not working
my indicators and hazard lights arent working on my 1990 xr3i any ideas please???
Old Jul 26, 2007 | 05:45 PM
o n i o n's Avatar
o n i o n
I would put money on it being the flasher realay.
You will find this plugged in to your indicator stalk switch once you have removed the steering column covers.
Should be a small 3 pin relay.
HTH
Old Jul 26, 2007 | 05:47 PM
zvhturbo29rs
hi mate replaced the relay with a brand new ford one still no indicators or hazards.no click from relay either.cheers
Old Jul 26, 2007 | 06:03 PM
Try vigorously working the HAZARD switch in/out a few million times, these often play up and all the indicators go through this switch.
Old Jul 26, 2007 | 10:32 PM
NUTS RuS's Avatar
NUTS RuS
Checked the fuses ?
Old Jul 27, 2007 | 07:37 AM
Aaroncast's Avatar
Aaroncast
-is the problem/fault just now and then!
Old Jul 27, 2007 | 06:57 PM
zvhturbo29rs
the faults there all the time. just put zvh in the car now not working
Old Jul 27, 2007 | 07:12 PM
NUTS RuS's Avatar
NUTS RuS
Is the relay getting power on the feed pin ?
Do you have a meter to check it ? Where abouts are you ?
Old Jul 28, 2007 | 02:17 AM
zvhturbo29rs
Default indicators
ill chech the live feed 2mow mate, didnt think bout that. will let you know how it goes.cheers
Vincereese
Sep 5, 2015 10:46 PM
RIB1122
Aug 12, 2015 08:51 PM
dlwarrior
Aug 5, 2015 10:19 AM
