radiator
Old Jul 24, 2007 | 11:15 AM
jawanne's Avatar
jawanne
Default radiator
hi i have mk3 escort 3i just wondering as when i put my turbo engine in can i still use my 3i radiator in any way i do have a s2 one but i just want it easyer to do .....thanks
Old Jul 24, 2007 | 11:27 AM
davsmith64's Avatar
davsmith64
well, i think a 3i radiator is bigger?? if so what intercooler you using??
and the main thing is,, if you are running a water cooled turbo you will need to modify the rad a little so that the water feed for the turbo can be fixed in place..
Old Jul 24, 2007 | 11:34 AM
jawanne's Avatar
jawanne
hi i guess the fan will need moving and some said that i can block the water pipes off on to the turbo is that safe and do you think it would be better if i used the s2 radiator....thanks
Old Jul 24, 2007 | 12:28 PM
SafeChav's Avatar
SafeChav
You'll have a right job fitting an intercooler with a 3i rad!
Ive got a S2 rad in mine, had to hand make a couple of brackets but didn't take long
Old Jul 24, 2007 | 03:04 PM
jawanne's Avatar
jawanne
so will the s2 radiator go in ok ..
Old Jul 24, 2007 | 08:39 PM
SafeChav's Avatar
SafeChav
it will but as i say its not a direct fit
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
