s2 dizzy help
Old Jul 19, 2007 | 10:49 PM
jawanne's Avatar
jawanne
Default s2 dizzy help
hi am putting a frst engine on s2 injection iand s2 loom n to my mk3 escort but i dont have a dizzy .wat dizzy do i need as some people i have asked said that i need a s2 one also can i use my 3i tank and fuel pump any info will be good thanks
Old Jul 20, 2007 | 10:15 AM
SafeChav's Avatar
SafeChav
Why on earth are you doing that may i ask?
Its more work in every area to put a FRST engine in a MK3 on S2 fuel management.
EFI it, and reap the benefits
Old Jul 20, 2007 | 12:21 PM
antony215's Avatar
antony215
Escort Rs Turbo
If you have a complet frst engine then id do as safechav said and go with EFI but to anser your question yes you need a s2 dizzy and you can use your tank and pump.
Old Jul 20, 2007 | 10:13 PM
jawanne's Avatar
jawanne
hi..i would used the efi but i got it with mfi and i have s2 loom and t3 and big cam ..but i need boost pipes and the dizzy. can any one help
Old Jul 20, 2007 | 11:46 PM
gup's Avatar
gup
ive got a full set of blue samcos (boost ones) if your interested for a mk3 came off my old s1 you can use the s1 dizzy too
Old Jul 20, 2007 | 11:58 PM
jawanne's Avatar
jawanne
hi am useing s2 intercooler and some one said that i would need s2 hoses
would they fit and have you got a dizzy
Old Jul 21, 2007 | 12:17 AM
gup's Avatar
gup
hoses wont fit right on a s2 intercooler fella
Old Jul 21, 2007 | 12:23 AM
jawanne's Avatar
jawanne
so wat do i have to do to use yours
Old Jul 21, 2007 | 01:03 AM
gup's Avatar
gup
the s1 intercooler outlet pipes are a slight or nearly straight so the pipes all virtually gone in a straight line
where as the s2 intercooler pipes are straight so the pipes have a bend in them to fit into the charge carrier
if this makes sense lol
if you fit your s2 intercooler at an angle so the outlet pipes are facing the charge carrier pipes in a straight line then you can run the s1 pipes
you'll understand when you look at them fella
15
Oct 7, 2015 03:43 PM
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
biggiejody
Sep 19, 2015 10:25 AM
Roosie
Aug 15, 2015 08:09 PM
