Zetec wiring/ loom Q
Old Jul 13, 2007 | 05:51 PM
Jamie200's Avatar
Jamie200
Default Zetec wiring/ loom Q
I'm planning on putting a 2.0 silver top Zetec into a 1990 efi mk4 XR3i.
I know of all the mechanical mods needed, and although I've trawled for ages on managment and looms, I still need some ideas:
I have the ecu and loom and engine from original efi xr3i.
I have all running gear and loom/ecu from K plate 1.8 105ps (non-pats)
I also have full car- 96 1.8 Si.
I want to use Ford parts so what ecu/loom combo do I use?
1: XR3i Efi set-up? (with inlet manifold adaptor plate)
2: either 1.8 set-up from above Escort? (Will this run 2.0 ok?)
3: Mondeo set-up if I get whole car?
I understand the loom needs modded to use 2.0 ecu, but is this only on 1.8 loom?
Does anyone have exact wires or connectors that need modded to fit 3i?
Thanks to all who reply.
Old Jul 13, 2007 | 08:03 PM
M1CH43L's Avatar
M1CH43L
no.2 sir and it ull run a 2.0l with the 2.0l ecu
Old Jul 14, 2007 | 04:01 PM
Jamie200's Avatar
Jamie200
Thanks, I think I have read that the wiring to the ecu needs changed around when using 2.0 ecu on 1.8 loom?
Old Jul 16, 2007 | 06:11 AM
Jamie200's Avatar
Jamie200
I thought more poeple had done this conversion?
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
muz
Sep 30, 2015 08:29 AM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
