s1 electrical
Old Jul 12, 2007 | 05:20 PM
syko2005's Avatar
syko2005
burning oil
Default s1 electrical
i dont think ive ever used my series 1 at night until this last week and have noticed a problem with the electrics. when i turn my lights on to full beam the battery light comes on but only dim. if i use the indicators it comes on brighter. but if i was to say use the heated rear window it dosent come on any brighter.also the car splutters when coming on boost and it only does this with the lights on. could this be lack of power to the fuel pump perhaps?. the battery is new and so is the alternator. just wondering where is the best place to start checking the elctrics or has any body else had a similar problem
Old Jul 12, 2007 | 06:48 PM
I would in the first instance check your charging rate, you want to see a minimum of 13volts at 2000 rpm with lights on.
The clean up all earths.
Old Jul 12, 2007 | 07:01 PM
syko2005's Avatar
syko2005
burning oil
thanks for that i think my mate has got a tester il check it out this weekend
Old Jul 12, 2007 | 07:19 PM
bluescortcossie's Avatar
bluescortcossie
as tabetha said check to see how well your alternator is charging and also check the engine earth strap
Old Jul 13, 2007 | 02:33 PM
SafeChav's Avatar
SafeChav
Common to almost every Mk3 on the planet mate, and in 99.9% of cases nothing to worry about.
It stems from a bit of resistance in the ignition circuit, so therefore with high load on the ignition circuits with headlights etc, the charging voltage from the alternator is slightly higher than that in the ignition circuit, thus giving a difference in potential, resulting in a faintly glowing bulb. Most of the ones ive had do it, never caused any problems though.
You'll probably also notice pushing the brake pedal makes the warning lights on the instruments surge, as will the indicators flashing etc
Nov 1, 2015 06:53 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
stevecfrst1
Sep 30, 2015 05:18 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Kam B
Sep 24, 2015 10:40 AM
