How does a rev counter work? what input?
Old Jun 24, 2007 | 08:55 PM
lucasdemoley's Avatar
lucasdemoley
Default How does a rev counter work? what input?
Right, as above really. I need to know what the input into the rev counter is on my fiesta 2.0 zetec (mk3)si. I have an idea for a rev counter accessorie but dont know if the input it a pulse, i.e 6k per min pulses at 6krpm, or like 6v for 6k rpm, or if its done on resistance or what. if someone could enlighten me, and give me a few rough numbers that would be awsome.
cheers
Old Jun 24, 2007 | 11:32 PM
SafeChav's Avatar
SafeChav
the signal is a switched earth, usually on the LT side of the coil
Old Jun 25, 2007 | 12:55 AM
lucasdemoley
Erm....? Basicly im getting a mate to make the thing up for me, as im crap with electrics, so have no idea what you just said! I get its done by like a missing tooth type thing on the flywheel sending a slat spot in a wave thing, but does this go through something else before being sent to the rev counter?
Old Jun 25, 2007 | 11:04 AM
SafeChav's Avatar
SafeChav
no its controlled by the LT signals which also fire the ignition coil.
Old Jun 25, 2007 | 12:06 PM
lucasdemoley
Ah ok, right. Do you have any idea what this signla looks like? I know which wire it is, im just wondering what the signal looks like as it will be going through a basic processor that a mate of mine will write some code for, but i need to tell him what signal he will be getting so he can write the code for the desired effect.
cheers dude
Old Jun 25, 2007 | 03:08 PM
SafeChav's Avatar
SafeChav
being as its just switched its a square wave
Old Jun 25, 2007 | 04:05 PM
lucasdemoley
So its a square wave that goes straight to the rev counter, so 6krpm would be 6k...... im forgetting its over a min, so it'd be like 100hz(3krpm 50hz)? would it be a 12v signal? or as its got 4 spark plugs would this have to be multiplied by 4?
Old Jun 25, 2007 | 04:07 PM
lucasdemoley
cheers btw
Old Jun 25, 2007 | 07:56 PM
SafeChav's Avatar
SafeChav
Well no not necessarily, different rev counters are calibrated accordingly, if the car is running coil packs then it could be running wasted spark or a coil for each plug!!
How could it be a 12v signal i said above it switches earth
Old Jun 26, 2007 | 11:18 AM
lucasdemoley
Soz, im crap with electrics, dont get what you mean by it switches earth???
Old Jun 26, 2007 | 11:26 AM
SafeChav's Avatar
SafeChav
Switches the negative side of the coil, so 0v.
Dahl88
Aug 22, 2015 08:16 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
ekjim
Aug 17, 2015 08:57 PM
cozzy jeff
Aug 14, 2015 05:46 PM
stevierob
Aug 11, 2015 09:08 PM
