Sierra hub options
Old Jun 20, 2007 | 01:32 PM
TTommy's Avatar
TTommy
Default Sierra hub options
Hi.
i have a sierra non cosworth sapphire. i want to have cossie hubs. can i just get some
2wd cossie rear hubs?
2wd cossie front hubs?
also can i use 4wd cossie front hubs without the shafts?
cheers.
Old Jun 20, 2007 | 04:03 PM
2wd cossie rear hubs yes + brakes!!
2wd cossie front hubs, yes but will need different TCA's as if you use 3 door ones as they have a TAPER fitting joint(in TCA), as opposed to castle nut.
I am sure that is the way round it is done it myself.
Front cossie 2wd brakes will fit STRAIGHT on a non cossie 2wd hub by the way, just got to tap the lug hole that's all, done that as well, major difference in braking dept!!.2wd stub axles do fit 4wd as far as I know but not 100% certain.
Old Jun 20, 2007 | 05:07 PM
TTommy's Avatar
TTommy
cool thanks for the info can anyone confirm that i can use the 4wd hubs witht the 2wd stubs? 4wd 909 stuff is easier to come by.
Old Jun 20, 2007 | 05:14 PM
Sorry mistake!!
Sierrasideways
Oct 8, 2015 06:37 PM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
yorkie92
Sep 6, 2015 05:34 PM
jc1989rs
Sep 5, 2015 08:09 PM
