SAFF COS CRANK PULLY.
Old Jun 13, 2007 | 07:21 PM
DALE 77's Avatar
DALE 77
Default SAFF COS CRANK PULLY.
HI FOLKS CAN ANY ONE POINT ME IN THE RIGHT DIRECTION.TO REMOVING MY F**K IN CRANK PULLY.ITS A 4X4 SAFF ON A K PLATE.ITS REALLY GIVING ME A HEAD SCRATCH. I HAVE TRIED 2 DIFFERENT PULLERS. BUT STILL NO JOY..I WOULD DRILL AND SMASH IT.BUT I CANNOT AFFORD A NEW PULLY AS YET.ANY HELP WOULD BE GREAT.THANX DALE
Old Jun 13, 2007 | 10:31 PM
CosKev3's Avatar
CosKev3
They are tight ain't they
Have you tried this type of puller???????
http://cgi.ebay.co.uk/COSWORTH-YB-TU...QQcmdZViewItem
Thats the type I used on mine,did the job
Old Jun 14, 2007 | 06:40 AM
If you have the three holes you are ok and best to use pulleer described above.
If no holes, try a bit of heat, but you will of course have to be very careful if it is a rubber bonded outer bit!!.
When(eventually), you do get it off, if you apply valve lapping paste between the pulley and crank nose where it sits, and gently grind it it will come off a lot easier in future, I was lucky, but know some can be seriously tight, best of luck to you!!
Old Jun 14, 2007 | 05:51 PM
DALE 77's Avatar
DALE 77
THANX GUYS...I HAVE TREID THAT TYPE OF PULLER THE PROBLEM WITH THAT 1 WAS 2 OUT THE 3 HOLES WERE STRIPPED..YES I DID THINK OF USING A LITTLE HEAT..TO LOOK AT THE STATE OF THE CAMBELT.I WOULD SAY ITS NEVER BEEN CHANGED.IT LOOKS LIKE SOME 1 HAD A GO AND GAVE UP..I HAVE TOOK IT OF THE ROAD IN FEAR OF THE BELT SNAPPING.I HAVE BEEN SOAKING IT IN WD40 EVERYDAY FOR A WEEK.
ILL KEEP TRYING...THANX AGAIN GUYS
Old Jun 14, 2007 | 06:17 PM
You will probably just have to go for it then, break it off if necessary, it is still a lot cheaper than a new engine!!
Old Jun 14, 2007 | 06:29 PM
DALE 77's Avatar
DALE 77
YES IT LOOKS THAT WAY.. I HAVE HAD A QUOTE OF Ł135 FOR THE PULLEY.AS A SECOND HAND 1 IS LIKE ROCKING HORSE SHIT..BUT YES ITS CHEAPER THAN A TOP END REBUILD..IF THE WEATHER IS O.K WEEKEND ILL CRACK ON WITH IT..
Old Jun 14, 2007 | 09:04 PM
cos jon's Avatar
cos jon
Is it to change the cambelt ??, you can change them without taking the pulley off if your patient !!
Old Jun 14, 2007 | 09:14 PM
DALE 77's Avatar
DALE 77
CAN YOU?.. WHATS THE MAGIC MATE :
Old Jun 15, 2007 | 06:07 AM
The magic is to bend the guide plate(dished washer) between the pulley and the drive cog for the belt, outwards creating a gap, fine if you want just hope you never have to take pulley off, as you are still stuck and so is the pulley.
I will have a look today to see if a puller that uses legs behind the lugs would be feasable to make.
Old Jun 15, 2007 | 01:23 PM
pacman's Avatar
pacman
Hi
Had this prob on my 2wd saph. In the end the one that worked for mine has 3 legs that goes outside the pulley and a centre bolt that tightens against ur slackened off pulley bolt and pulls the pulley forward.
Its at home so if you wish i will check the make etc and post details later.
Old Jun 15, 2007 | 02:00 PM
I think(?) the 4x4 ones are all "balancer" type ones with the seperate outer ring bonded on.
Old Jun 15, 2007 | 06:13 PM
DALE 77's Avatar
DALE 77
THANX GUYS...I USED THE 3 LEGGED PULLER.AND BELIVE IT OR NOT.1 OF THE LEGS BROKE..I DID SEE A STRONGER VERSION 2DAY IN THE SCREW FIX DIRECT CAT AT WORK IT WAS Ł12 MIGHT GIVE THAT AGO.IM GOING TO HAVE A GOOD GO AT IT 2MORROW..ITS NO FUN ON A MOTORBIKE IN THIS WEATHER LOL....
Old Jun 15, 2007 | 07:07 PM
cos jon's Avatar
cos jon
I changed the cam belt on my escort without having to bend anything at all, you just have to feed the belt in horizontally while rotating the pulley wheel, eventually it will pop in (have to be carefull not to damage the belt) but mine took about an hour in total to do.
There was also a post on this a while ago, i'll see if i can dig it out
Old Jun 15, 2007 | 07:24 PM
I read other posts saying how you could do it by bending the metal washer guide bit type thing, never done it this way myself.
Old Jun 15, 2007 | 08:24 PM
DALE 77's Avatar
DALE 77
BRILL ILL GIVE THAT A GO..
Old Jun 15, 2007 | 08:46 PM
Doug's Avatar
Doug
As tab sais you can do it without removing the pully and bending backing washer bit of a piss poor way but will take you 30 mins and a lot of hassle saved ( although !!! ) I would rather do it the correct way but each to their own and if it gets you out of shit for the moment .
Regards Doug .
Old Jun 16, 2007 | 06:53 AM
You are going to have hassle over this issue at SOME TIME, when a crank seal goes for example, might as well get it over with now ?, by doing it right, but up to you.
Old Jun 16, 2007 | 05:27 PM
DALE 77's Avatar
DALE 77
HI FOLKS! JUST AN UPDATE ON THE COSSIE CRANK PULLEY..IN THE END I DECIDED TO DRILL PILOT HOLES FROM THE SIDE.AND SMASH IT OFF WITH HAMMER&CHISSEL...ALL DONE JUST GOT TO GET NEW PULLEY NOW..THANX FOLKS FOR ALL THE HELP
Old Jun 16, 2007 | 05:45 PM
No chance of SUPER GLUE THEN!!!
Old Jun 16, 2007 | 06:05 PM
DALE 77's Avatar
DALE 77
LOL.DEFF NOT
cossie330
Sep 27, 2015 04:13 PM
ajamesc
Sep 27, 2015 02:25 PM
`spotty
Sep 25, 2015 11:41 PM
timsrs
22
Sep 24, 2015 08:14 PM
coscor86
Sep 20, 2015 01:21 PM
