no spark (cossie)
Old Mar 26, 2007 | 02:26 PM
scottysnewsaff's Avatar
scottysnewsaff
Default no spark (cossie)
just done the head on my 2wd saff put it all back together and there is no spark through the ht leads but there is through the coil so something is happening in the dizzy cap or roundabout there sometimes it will spark but only once, something simple or bad connection i guess?? all plugs leads dizzy cap and rotor are brand new also please any suggestions??
Old Mar 26, 2007 | 04:29 PM
if it is intermittant first check the gaps plugs 0.6mm, phase 0.2-0.3mm,CPS 0.6-1.0mm.
if still iffy look at CPS connector next.
Old Mar 26, 2007 | 04:31 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Don't forget the obvious either - I had one pot not firing on mine after I changed the leads - one of the leads wasn't seated fully and had slipped off the cap.
It is f***ing tight down there!!!
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
deathrider666
Sep 28, 2015 06:12 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
