Apexi AVC-R
Old Mar 24, 2007 | 01:26 PM
Nash's Avatar
Nash
Cake lover!
Default Apexi AVC-R
As above does anyone know where i can take the wheel speed from? I think its either pin 22 or 27 on the abs ecu, but will this still work as i dont run with the abs connected?
Thanks in advance.
Old Mar 24, 2007 | 03:52 PM
SafeChav's Avatar
SafeChav
Have you got a sensor on the gearbox speedo drive?
Old Mar 24, 2007 | 05:42 PM
Nash's Avatar
Nash
Cake lover!
Yes but need a digital signal thats the problem.
Old Mar 24, 2007 | 05:45 PM
SafeChav's Avatar
SafeChav
A speedo speed sensor is square wave, is it not?
Old Mar 24, 2007 | 06:27 PM
Nash's Avatar
Nash
Cake lover!
I was sure i couldnt take it off the gear box as the Stack dash lads have to same problem, or i thought they did. They buy an extra sensor but thats ŁŁŁ and was trying to find something cheaper first.
Old Mar 24, 2007 | 06:29 PM
SafeChav's Avatar
SafeChav
Hmmmmmmm, im sure you can
Ive got an AVC-R its been in the box 2 years, dont remember reading about the speed sensor being digital though.
Old Mar 24, 2007 | 10:13 PM
Badman38's Avatar
Badman38
you can use a standard gearbox speed sensor i have just fitted an avcr paul hill @engine advantages set it up for me. i had to go to the scrape yard and get a speed sensor off an xr2i due to me throwing the one that came with my car in the bin years ago.... what an excellent bit of kit boost comes in more progressive as the revs climb alot smoother holding 30psi and i like the display... well worth the money
Old Mar 24, 2007 | 11:21 PM
SafeChav's Avatar
SafeChav
Thought so
The speed sensor on the gearbox will be square wave output, im sure it has a wide input range!
Old Mar 25, 2007 | 01:20 AM
Nash's Avatar
Nash
Cake lover!
Cool cheers lads
Best get my arse in gear when i get my car back, and fit it now.
YODI
Aug 30, 2015 01:12 PM
banhambuilt
Dec 5, 2006 11:41 AM
GUZZLER
Ford Escort RS Cosworth
21
Sep 1, 2006 09:37 AM
MarK4
27
Jul 15, 2004 11:11 AM
MarK4
42
Jul 14, 2004 04:45 PM
