1300 - 1600 swap
Old Feb 25, 2007 | 01:11 PM
rsfido_1989's Avatar
rsfido_1989
Default 1300 - 1600 swap
elo all i have a 1300 carb'd escort with a blown headgasket .. want to change to a 1600 carbs cvh.. what work is involved in this? cheers
Old Feb 25, 2007 | 01:22 PM
SafeChav's Avatar
SafeChav
Should be a straight swap mate.
Can't see there being any obstacles in your path on that!
Old Feb 25, 2007 | 01:39 PM
rsfido_1989
what about wiring as its not a cvh in it ??
Old Feb 25, 2007 | 02:58 PM
SafeChav's Avatar
SafeChav
Ah! Then yea that will be a lil bit of a kerfuffle
I think of everything in MK3 terms, which also has 1.3 CVH's. Shouldnt be too hard even so. A few wiring mods but it will be simple enough, you'll have to bin the ESC ignition module on the inner wing that the HCS uses.
chowfornow
14
Jan 5, 2019 09:01 PM
cossie brad
Sep 29, 2015 02:38 PM
chowfornow
Sep 19, 2015 10:47 PM
grishenko45
Sep 9, 2015 12:58 PM
