"Ghost" noises from the strut/axle
Old Jan 10, 2007 | 06:58 PM
m0n0x1d3's Avatar
m0n0x1d3
Default "Ghost" noises from the strut/axle
A little while ago i managed to fit some 16" alloys with 195/45 tyres on my Ford Fiesta MK4 99 1.4 Zetec model.
It's a tight squeeze, the alloys went on but there are some problems, there's the occasional knocking sound aroudn the area where the strut is. I've replace both anti-roll bar brushes which seemed to have eased it a little. I can fit my fist into the space between the wheel and the arch above but thats about it..I can barely fit my little finger between the wheel and the strut.
I had a problem when i first put them on that the strut would move slightly before the wheel actually turned, it didn't matter how much i tightened the alloy on. Probably a little stupid fitting 16's on a car designed for 13/14's but they were OZ SuperT's going cheap. My guess is the wheel's just too big and heavy however i want to keep the set.
I don't want t sell the car as i've already replace the radiator fan, clutch, ignition etc. which has cost me a pretty penny. It's done 73k miles but i bought it for £500 at 69k so i wasn't bothered.
Basically i want to reduce this loud 'knocking' noise, it's not constant but it happens and it's not a pretty noise, usually happens when i'm setting off with the wheels turned. I also want to be able to lower my suspension. My car looks like it's on stilts at the moment so i thought 25mm hard lowering springs should do it. But i'm not so sure as if i have people in the back when going up hills or i turn corners sharply (attempting to drift the car or handbrake slide) i can feel the tyres rubbing against the arch.
Any ideas??
Also i noticed if you want to fit an induction kit on a mk4 you have to get the whole kit and re-pipe quite a bit...bit of a pain..anybody got any quicker and still as effective ideas?
Old Jan 10, 2007 | 07:23 PM
All right mate have u tried putting ur old wheels back on n c if it is the wheels.My girl friend used 2 have a mk 4 1.25 16v n i put a k an n performance filter on hers i took the air filter box out n used the original pipe n fitted the filter straight onto the air flow meter
Old Jan 10, 2007 | 10:40 PM
m0n0x1d3's Avatar
m0n0x1d3
Unfortunatly i sold my standard wheels, needed cash. I'm positive it is the wheels causing the strain as the previous owner never had any problems and i never had that problem when i first bought the car. The knocking is less than a few months back, either it's worn itself in a little or. It reminds me of something straining and then clicking back into place.
Old Jan 13, 2007 | 03:38 PM
Have u made sure ur wheels r sat on the hubs correctly n they r the right wheel nuts n are tight enough ive work on cars where when the wheel is on full lock on the steering n pull away the wheels used 2 give of a big cracking noise
gingeRS
17
Oct 2, 2015 09:42 AM
Botts
Sep 22, 2015 02:04 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
rsturbo27
Sep 5, 2015 05:08 PM
