Series 2 starting problem when hot
Old Dec 11, 2006 | 09:15 AM
GAZ-MAN's Avatar
GAZ-MAN
Default Series 2 starting problem when hot
hi all, when i start it in the morning when it is cold it is fine, and when it is heaten up and i stop say at the shop in the morning on my way to work when i start it again and miss the first fire up itll just turn over for ages eventually firing up if the battery dosnt go flat, if i bump it itll bump fine, any ideas?
Old Dec 11, 2006 | 05:35 PM
SafeChav's Avatar
SafeChav
Probably a weak starter mate. Very common to all CVH engines but especially the forced induction engines.
Do a search you should find no less than about 324354321 topics on it
Old Dec 12, 2006 | 06:24 PM
slider's Avatar
slider
could also be the non return valve in the fuel pump has had it, if the engine turns over ok the starter is fine, it'll start from cold because the cold start injector will give it the extra burst of fuel it needs to fire which in turn opens the metering flap and pulls fuel through to the main injectors, same applies to bump starting.
if the non return valve has had it there will be no risidual pressure to the metring head which is why when you crank if you are liucky itll fire but only briefly, after that you need to just crank the engine which will eventually get rid of the air lock created in the injector pipes and start,
this may sound crazy but i had the same thing on my s1 and my rs1600i, both were ok from cold and would only warm start if tried within 5 minutes or bumped or if i pushed the flap down on the metering head,
you can fit an aftermarket non return valve after the fuel pump but just make sure its rated at min 7 bar pressure
Old Dec 12, 2006 | 08:54 PM
GAZ-MAN's Avatar
GAZ-MAN
that sounds about it mate, any ideas where i can get a non return valve thingy mate haha?
Old Dec 12, 2006 | 10:48 PM
SafeChav's Avatar
SafeChav
slider.....thats not true, my cabriolet had the 1 way valve knackered and ive never connected the cold start valve. Used to start fine from cold.........but not when hot
And an engine doesnt go cold in half an hour!
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
