Mondeo Blower/Fan Problem
Old Dec 5, 2006 | 10:54 AM
safetymatt's Avatar
safetymatt
Default Mondeo Blower/Fan Problem
anyone have any ideas on a problem my old man is having.
He has a Mondeo and when you put the blower on it only works on setting 4, its blows and sounds normal for about 3 seconds then it changes to a more louder noise, almost as if something is blocked.
Anyone got any ideas, im fed up of him moaning about it??
Old Dec 5, 2006 | 11:52 AM
bluescortcossie's Avatar
bluescortcossie
not sure about the noise change but my mate had a mk1 mondy and that did the same , never heard it on my mk2 , its probably the direction flap thing moving as for them only working on number 4 setting the resistors have burnt out , they are available from ford but they not cheap , better off going to a scrappers , the resistor block is under the dash on the passenger side / to the right of the footwell , its a little white block with a plug on it and is held in with 1 screw or sometimes riveted on
hope this helps
Old Dec 7, 2006 | 02:46 PM
Avinitlarge's Avatar
Avinitlarge
Sound like the resistor pack has packed in, VERY common fault
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Brickhouse
Sep 20, 2015 11:47 AM
roomey
Sep 19, 2015 08:40 AM
Flateric_2002
Sep 15, 2015 08:41 AM
