Cosworth throttlebody
Old Dec 1, 2006 | 11:32 AM
JanDK's Avatar
JanDK
Default Cosworth throttlebody
Is there anybody who know how to check the adjustment or baseadjust the throttlebody butterfly (NOT tps)
I think someone before me have adjusted a bit to much on it. I can se a lot of screwdriver marks around the screw.
Old Dec 1, 2006 | 12:14 PM
jon@work's Avatar
jon@work
if you mean the small throttle stop grub screw (as opposed to the idle speed adjustment screw) then on the throttle bodies I have seen the screw may as well not be fitted, as it doesn't sit against the shaft-mounted lever with the butterfly shut
Old Dec 1, 2006 | 12:22 PM
JanDK's Avatar
JanDK
That is the one I mean, yes... idle speed screw.
I am not sure I undertsand what you say... can I remove the screw, and hardly feel any difference??
My screw as I see it, activates the butterfly just a bit.. I think it makes a diffenrence on my idle.... and maybe my "idle" when braking with the engine from high speed (dont know what it is called in english ) It sounds like it is fueling a little bit in the exhaust, and gives little throttle it judder alot!!!
Old Dec 1, 2006 | 02:52 PM
jon@work's Avatar
jon@work
to clarify, do you mean screw 1 or screw 2 ?
Old Dec 2, 2006 | 02:54 PM
JanDK's Avatar
JanDK
Screw number 2
Old Dec 2, 2006 | 05:09 PM
jon@work's Avatar
jon@work
as above then :
Old Dec 2, 2006 | 05:13 PM
JanDK's Avatar
JanDK
Thank you Jon .... I will try to unscrew it and and again adjust the tps once again, then se what happens.
Billy_RS
Sep 13, 2015 04:17 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
