P8 ecu query...
Old Dec 29, 2003 | 02:45 PM
Dave Henshall's Avatar
Dave Henshall
Default P8 ecu query...
does anybody else notice this.... or is this the root of my problems...?
when the batery has been disconnected for some time (a week or so) when its been in storage/ repair, wheni reconnect it, then turn the ignition key, neither the fuel pump or ISCV operates for about 30 seconds. once it has run, they work straight away.
i'm thinking that this may be linked with its cutting out problem. the ignition relays drop out (momentatily) causing the car to miss. it is defo the relays, ive had a multimeter on them and its not the live side that is the problem. its the switched earth side - which surprise surpirse is routed through the ecu. had anyone else had anything similar - ive heard of P8 syndrome - have i got it...?
Old Dec 29, 2003 | 08:26 PM
DazC's Avatar
DazC
P8 syndrome is where the ECU drops in and out of limp home mode for no reason...moody ECU...obviously female.
Is the ECU at fault or is it something the ECU is sensing and is cutting the fuel pump off momentarily?
Old Dec 30, 2003 | 12:06 PM
Dave Henshall
i know that if i go from the live side of the relays to earth, they are at a good 12 volts all the time. when the relays click out/in again the voltage does not budge on the live side which point to the earthing through the ecu. the earths have all been cleaned and checked and are around 0.3 ohms.
when it goes into limp mode..... it still runs but at reduced boost i take it... and then it comes back after seveal seconds once you have let it idle for a few seconds... this sounds familiar, ...
Old Dec 30, 2003 | 09:38 PM
DazC's Avatar
DazC
Won't rev past 4k in limp home..... I assume it will only run limited boost as well.
The ECU controls the earth....they don't just go through it. If the ECU doesn't have all the right signals from all the sensors it can drop the earth as soon as it sees a problem.
Old Jan 5, 2004 | 07:38 AM
Dave Henshall
thats what its doing - i know the ecu switches the earths - but does anyone know whatr happens when it swaps from normal to limp - does the ecu stop/start itself - which would explain the probs im having?
Old Jan 5, 2004 | 10:25 PM
DazC's Avatar
DazC
You need to ask Stu @ Motorsport Developments mate. He knows shite loads about the Marrelli ECU's.
I can't help you anymore unfortunately.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
