IS IT OVERFUELLING SAPH
Old Aug 23, 2004 | 01:00 PM
yogi's Avatar
yogi
Default IS IT OVERFUELLING SAPH
JUST HAD A BOTTOM END REBUILD ITS A STAGE 1 2WD SAPH WELL ITS RUNNING ABOUT 13PSI BUT THE CAR IS GETTING ABOUT 35MILE FOR A TENNER I THINK THIS IS EXCESIVE AND ON START UP THERE IS BIT OF BLACK SMOKE WHEN COLD BUT WHEN YOU PUT YA FOOT DOWN FOR A RUN YOU CAN SMELL PETROL I TOOK IT TO GET TUNED UP AND THE FELLA SAID IT MIGHT BE RUNNING RICH BUT WHEN I WENT BACK TO PICK IT UP HE SAID IT WAS RUNNING A BIT LEAN SO HAS TURNED IT UP A BIT ANY IDEAS THE REVS STAY A 1000RPM ON IDEL SO THATS FINE
Old Aug 23, 2004 | 01:43 PM
wimwerf's Avatar
wimwerf
i guees your fuel lines are not leaking, and your fuel pressure regulator...is it ok. and your CO.
Old Aug 23, 2004 | 07:42 PM
yogi's Avatar
yogi
as far as i no there is defo no leaks been under and checkedot sure about pressure regulator but i thought co would have been adjusted when i got it tuned up any other ideas how do i check the pressure regulator
Old Aug 24, 2004 | 07:36 AM
Stu @ M Developments's Avatar
PassionFords Creator
Get her checked by someone with the correct equiptment to do it ON THE ROAD...
CO checks at a standstill are neigh on totally pointless...
Old Aug 24, 2004 | 09:50 AM
yogi's Avatar
yogi
ok ill book her in for a rollin road cheers stu
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
landaqmabba
Sep 15, 2015 07:16 PM
