External Wastegate
Old Sep 15, 2006 | 07:38 AM
snedboy's Avatar
snedboy
Default External Wastegate
Is it possible to fit this to my standard cossie engine and is there anymore bits ide need??
http://cgi.ebay.co.uk/ws/eBayISAPI.d...%3AUK%3A1&rd=1
Old Sep 15, 2006 | 09:56 AM
jon@work's Avatar
jon@work
yeah there would be more to spend - it'd cost you a few hundred quid on top of that purchase price - don't go there unless you have to
Old Sep 15, 2006 | 10:18 AM
snedboy's Avatar
snedboy
Cheers m8.
Just out of interest what kinda money we talkin here and what parts aswell?
Cheers.
Old Sep 15, 2006 | 12:43 PM
jon@work's Avatar
jon@work
Fuck. I knew you'd ask that.
Well to start with if you've got a 2wd exhaust manifold, you'll need to replace the trousers with something like the item Martin at Reyland sells for, IIRC, £288 to mount the wastegate on. Then you'd have to make up the screamer pipe. Then you'd probably have to have the boost control checked/adjusted. Then you'll find that you're no better off than what you were running previously. Apart from you're skint.
You really don't need one unless you've got a turbo without an internal wastegate eg a GT30 (although you can get a version of this that does have an internal wastegate so you still won't need one)
Old Sep 15, 2006 | 03:07 PM
snedboy's Avatar
snedboy
Thanx alot for that m8.Good info there.
Would a 3 Bar Map Sensor be any good for my car then? Its running 10psi but i would like to up that to approx 12/14psi max.
Cheers again.
Old Sep 15, 2006 | 09:56 PM
jon@work's Avatar
jon@work
no - stick with the 2 bar until you get greens fitted (803s) for 330 brake, or it'll run like a bag of shit with a 3 bar
Old Sep 15, 2006 | 11:59 PM
snedboy's Avatar
snedboy
Thanx again m8 savin me some cash here
Old Sep 16, 2006 | 12:35 AM
jon@work's Avatar
jon@work
you want to save more cash ? sell your car
Old Sep 16, 2006 | 02:09 AM
snedboy's Avatar
snedboy
why? i dont wanna save that much
May 31, 2016 09:28 PM
pabloXR
Sep 21, 2015 12:42 PM
coscor86
Sep 20, 2015 01:21 PM
RSBryden
Sep 6, 2015 08:39 PM
Aug 14, 2015 07:29 AM
