2wd 4wd looms same?
Old Aug 11, 2006 | 06:38 PM
cosmatt's Avatar
cosmatt
Default 2wd 4wd looms same?
Ive got a 2wd saff that ive just removed the engine loom from as its knackered. I bought another one off tinternet and think its a 4x4 as its got the bulkhead multi plugs. Will i need to change anything or will it be ok on a level 6 ecu? Thanks for any help
Old Aug 11, 2006 | 10:05 PM
CosKev3's Avatar
CosKev3
Outer wires on the TPS plug will need swapping over for deffo
Not sure on anything else,think you might have a couple of plugs spare on 4x4 loom,depending on age of 4x4,(knock sensor/lambda sensor)
Old Aug 12, 2006 | 08:28 PM
cosmatt's Avatar
cosmatt
Cheers matey. There is couple spare but its in now and running again.
Old Aug 12, 2006 | 08:39 PM
EssexBoyRacer's Avatar
EssexBoyRacer
the water temp gauge may not reach as the sensor is in a different place on the 4x4 head.
also I think tps wires need swapping as mentioned.
but l6 loom will defo run on a 4x4 loom.
muz
Sep 30, 2015 08:29 AM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
