hand brake
Old May 6, 2006 | 03:42 PM
barry0777's Avatar
barry0777
Default hand brake
as above on a escos its so sloppy fitted new calipers and tightend cable and light is on dash and is crap it dosent hold and dosent handbrake eaither have got a new disk covertion to 300mm shall irenew the hand brake cable????
Old May 6, 2006 | 04:00 PM
Azrael's Avatar
Azrael
Light is on on the dash? You have some major problem not only handbrake...
Old May 6, 2006 | 04:23 PM
barry0777's Avatar
barry0777
any ideas what???as idont like the sound of it???
Old May 6, 2006 | 04:28 PM
Azrael's Avatar
Azrael
The light will sta on when electric pump cannot achieve proper pressure. Firts thing - try to check if rear brakes work at all and try bleeding them.
Old May 7, 2006 | 03:10 PM
barry0777's Avatar
barry0777
ok have bleed then and the caliper working correctly any more info chears matey
Old May 7, 2006 | 03:12 PM
Azrael's Avatar
Azrael
Is it ABS light or just brake light that stays on? Or both?
It's beyond my knowledge I'm afraid :-(
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
