S2 WONT IDLE
Old Mar 21, 2006 | 07:58 PM
robbob's Avatar
robbob
Default S2 WONT IDLE
MY S2 WONT IDLE SEEMS OK WHEN FIRST STARTED WHEN COLD BUT AFTER THAT WONT IDLE HAVE TO KEEP REVING IT AND WHEN IT DOES IDLE IT SEEMS TO GO UP AND DOWN LIKE ITS REVING IT SELF
Old Mar 21, 2006 | 11:04 PM
biglee's Avatar
biglee
Audio specialist
hi mate, my old s2 used to do the exact same thing, it was(belive it or not) low oil pressure on idle causing the engine to "hunt" (rev up and down) aparently the lifters were compressing and not letting some valves open properly, so when it was cold the oil was thick and pressure was good and idle was good but when the oil warmed up it went alot thinner as do all oils thus causing the problem,
or it could always be an air leak...
idle control valve leaking or knackerd.
worn camshafts can cause hunting.
and depending on what fuel system and control you are using...your cold start valve/injector may be playing up.
Old Mar 25, 2006 | 01:21 PM
SafeChav's Avatar
SafeChav
Good old air leaks may cause this aswell......
fordrallycar
Sep 30, 2015 07:57 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
