torque settings on cossie head
hi folks i want to put my head back on but the torque settings say stage 2 is 70 then stage 3 is 170-180 degrees more , the problem is i dont have a angle torque wrench so i wondered if there was a setting i could use rather than trying to find or borrow a wrench off someone cheers cosbag
You have to tighten them down using set angles as they are stretch bolts, so they are disgned to be set under a amount of tension via the amount youve stretched them by (lol could have worded that bit better i'm sure...but its late)....using a torque wrench wont work. Just by a angle gauge...cheap ones are only a few quid and no matter how much it costs ie cheapo or Snap-on, they all do the same job to the same standard.
Stu.
Stu.
Yeah its easy if you've done it before but, if he's gotta guess 70 degrees as well.....a cheapo angle gauge is under a fiver and if I were a novice I'd pay the fiver just for peace of mind lol
Stu.
Stu.
Originally Posted by CosKev3
Easy m8,just think of a circle or clockface
180 degrees is from 12 o'clock down to half past 12
Or half a circle if thats easier to understand
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
