4x4 throttle position sensor
Old Mar 15, 2006 | 07:44 PM
daveugc's Avatar
daveugc
Default 4x4 throttle position sensor
hi how can i cheek that the tps is in the right position any help would be great
Old Mar 15, 2006 | 11:11 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Try these links (found by running a search here : https://passionford.com/forum/search.php )
https://passionford.com/forum/viewto...tps+adjustment
https://passionford.com/forum/viewto...&highlight=tps
TPS pins in relation to ECU connector (easier to read voltage off ecu connector pins on PCB if you remove the ECU cover) - note 2wd and 4x4 differences.
Be aware that the settings are different for 2wd and 4x4, I noticed 4x4 in your title so ignored any search results related to 2wd.
Good luck and welcome to PF (Judging by your post count)
Old Mar 16, 2006 | 09:11 AM
daveugc's Avatar
daveugc
thanks alot
Old Mar 17, 2006 | 11:42 AM
Dave Henshall's Avatar
Dave Henshall
as above - but either way - you will find that if it is ajusted to almost exactly half way along its elongated holes, you will not be far off. of a 4x4 one, with the ignition on, between pins 30&17 at the ecu, you should read 0.25 to 0.3 volts DC if its ajusted correctly
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
mike elsome
Sep 14, 2015 04:08 PM
tib2220
Sep 14, 2015 12:33 PM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
