testing radiator fans
Old Jul 27, 2004 | 07:12 PM
Moonstone Kev's Avatar
Moonstone Kev
Default testing radiator fans
Does anybody know how to test radiator fans to see if they are working on a 3dr cossie?
Old Jul 27, 2004 | 07:30 PM
sm's Avatar
sm
dont know about a 3door but on a erst u take off the plug on the thermo time switch and then put each end of a piece of wire into the holes on the plug and the fan spins up should be the same for a 3 door
hope this helps
cheers kev
Old Jul 27, 2004 | 07:46 PM
rocar's Avatar
rocar
Yes your right ,take the fan switch plug and bridge the two terminals,if the fans work replace the switch if still do not work see if you have any burning sign in the fuse box ,this is very common .
Roger
Old Jul 27, 2004 | 09:51 PM
DazC's Avatar
DazC
hope this helps
cheers kev
If you bridge out the thermo time switch then it will just fire the cold start injector every time you crank your engine over instead of just when cold....
You mean the fan switch.....
Old Jul 28, 2004 | 04:48 AM
rocar's Avatar
rocar
The Fan switch(on the radiator),Cosworths does not have thermo time switch.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
