HUB NUT
Old Mar 2, 2006 | 11:03 AM
monkey24's Avatar
monkey24
Default HUB NUT
What size is the front hub nut for a ford orion 1993 1.8i ghia?
need to get a socket so i can change my brake disks
Old Mar 2, 2006 | 11:47 AM
jonnyturbo's Avatar
jonnyturbo
are you sure you need to undo the hubnut to remove the discs???
Old Mar 2, 2006 | 11:56 AM
monkey24's Avatar
monkey24
never done them before so no im not sure if thats how they come off
Old Mar 2, 2006 | 12:57 PM
monkey24's Avatar
monkey24
it says in the haynes manual "using a torx-type socket, unscrew the screw securing the disc to the hub and withdraw the disc"
i cant find no securing screw torx or anything else.
Old Mar 2, 2006 | 01:23 PM
monkey24's Avatar
monkey24
sorted now.
Old Mar 2, 2006 | 05:34 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
its a 32 mm but u def dont have to remove that for to do ure brakes,
remove brake pads by 2 7mm hex bolts,then remove carrier 2x19mm bolts i think then remove small grub screw holding on disc if it dosent come of get big hammer and knock fk out the disc from the rear of it
the end
refit same as but without big hammer lol
Sierrasideways
Oct 8, 2015 06:37 PM
fordrallycar
Sep 30, 2015 07:57 PM
DavidK
Sep 27, 2015 02:55 PM
jc1989rs
Sep 5, 2015 08:09 PM
