How should I remove the Escos Dashboard ???
Old Jul 23, 2004 | 01:58 AM
Kezmo's Avatar
Kezmo
Default How should I remove the Escos Dashboard ???
Please tell me the easiest way to remove the Dashboard im my Escort Cosworth, Is there any cables to remove before or..??
Thanks/ Michael K
Old Jul 26, 2004 | 06:47 AM
Kezmo's Avatar
Kezmo
plaease help!!
Old Jul 26, 2004 | 07:31 AM
wimwerf's Avatar
wimwerf
first you begin with your steering wheel. and then you take of all the switches of. (mark with tape all the cabels, and write on from which switch it was), every part of dash you take..lay it apart with all the screws so you can't go wrong. maybe you have also take the plastic thing around your gearstick off.
good luck. I've done it ones..it's not hard to do but its a lot of work.
Old Jul 26, 2004 | 06:25 PM
wimwerf's Avatar
wimwerf
did you read it Kezmo.
Old Jul 27, 2004 | 10:38 AM
Kezmo's Avatar
Kezmo
I read it now! I will try it, I also have a airbag but i don't think it can blow since I got no battery in it.
Thanks!
Old Jul 27, 2004 | 12:54 PM
wimwerf's Avatar
wimwerf
I forgot you have an airbag. don't know how you take that off
boeb
Jan 9, 2020 05:11 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Orion_Gav
Sep 29, 2015 04:50 PM
