Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
L8 vs P8
Old Jul 14, 2006 | 08:25 AM
sygjim's Avatar
sygjim
Default L8 vs P8
What is the advantage to fit a P8 in the place of the L8
Old Jul 16, 2006 | 09:17 AM
sygjim's Avatar
sygjim
nobody
Old Jul 17, 2006 | 07:50 AM
Lou Lou.'s Avatar
Lou Lou.
Oh i could do with an answer to this aswell as have been offered both and at the mo its down to price
Old Jul 17, 2006 | 08:40 AM
Stu @ M Developments's Avatar
PassionFords Creator
If you dont want ALS. use the far cheaper and more reliable L8.
Old Jul 17, 2006 | 11:02 AM
Lou Lou.'s Avatar
Lou Lou.
Ok will do cheers Stu
Old Jul 17, 2006 | 01:37 PM
sygjim's Avatar
sygjim
ok, but if you have the l8 and p8 ecu, i suppose that p8 run quicker than l8, you have closed loop as standard .............
Old Aug 4, 2006 | 04:28 PM
foreigneRS's Avatar
foreigneRS
Testing the future
so what if p8 does run quicker?
if you have a 4 cylinder engine running at 8000 rpm, how quickly do you need the ecu to be?
not very quickly in processor terms, as you only have an injection or ignition event every 0.00375 seconds (so about 4ms, or 250 Hz). not exactly talking pentium 5 GHz speeds necessary here are we?
8000 / 60 = 133.3 revolutions per second
it's a 4 stroke engine, so you divide that by 2 revolutions for each complete cycle = 66.6 cycles per second
each cycle has 4 ignition or injection events = 266.6 events per second (Hz)
(you have crank position sensor events more frequently, depending on how many teeth on the pulley, but that's only twice as often a 4 lug pulley, although a lot more often on a 36-1 pulley)
Old Dec 17, 2006 | 03:51 PM
JanDK's Avatar
JanDK
Will L8 be a straight swap in the Escort???
Old Jan 28, 2007 | 07:41 AM
Dave Henshall's Avatar
Dave Henshall
it will, but you need a L8 chip that has been written for the engine, as it has a differenmt turbo and map sensor...
unless you already have a L8 chip for a T34 and a 3 bar map on greens
Old Mar 30, 2008 | 09:46 AM
Just to update this topic... we now offer ALS and launch Control for all Level 8 ECU's as well.
