My 1989 RWD Sapphire Cosworth restoration underway, its on the jig!
Old 24-04-2015, 09:04 AM
  #81
Matty_C
Matty_C's Avatar
Colin's a decent guy he's serviced mine a couple of times and took it for an mot.
Old 29-08-2015, 05:16 PM
  #82
stu20004x4
mk6 escort fantasist
stu20004x4's Avatar
Default put her new shoes on the other day
Old 29-08-2015, 05:46 PM
  #83
SMILER258
SMILER258's Avatar
Looks ace but personally prefer standard shoes. What's the mini?
Old 30-08-2015, 06:45 PM
  #84
Received 1,044 Likes on 998 Posts
Nice wheels but they need to be silver imo
Old 30-08-2015, 08:41 PM
  #85
stu20004x4
stu20004x4's Avatar
Ive kept the originals, but I need bigger brakes for track days hence bigger wheels. Colour will be getting changed after show season too, I will be dipping them too!
Mini is a rover mini mayfair on a g plate, an eBay impulse buy for the wife lol, needs a resto
Old 01-09-2015, 08:06 PM
  #86
gjh
gjh's Avatar
I like those wheels.
Old 22-06-2016, 03:32 PM
  #87
stu20004x4
stu20004x4's Avatar
its been a while since i posted here, during which time, ive decided to give the old girl a bit of a resto. although she was driving brilliantly, it did have an issue changing down into fourth, syncro i suspect. so shes now in my unit, and ive been doing bits and pieces as and when i can.
seeing as i was taking the gearbox out, i figured i may as well take the lump out also, get it checked out by a pro, gaskets stem sills etc, the usual.
turns out its actually got a 200 block, and 2wd head. bonus!
it also has
rs500 intercooler
turbo intercooler
air injection
3 bar map sensor
it is a t34 (i have learnt alot since my earlier posts lol)
and many other goodies. i whipped the cam cover off too, and its got the arp stud and nut kit. will be sending it somewhere for some love soon, tempted to long stud it etc, go for over 400 hp and beyond.
turbo has slight play in, so that will be off for a rebuild, or sold/swapped for a t38, or any other recommendations?
any who, engine box out, i stripped the interior as i knew of a couple of little patches that needed doing, a penny hole in the foot well, and found two similar sized holes in the tunnel. thats all ive found for now, but im yet to uncover the sills, and i know from my past experience with the escorts, they are never in great shape!
lastly, i spent a few hours on it today, removed most of the bits and bobs from the engine bay, then the prop, rear sub frame, diff and suspension etc. all of which is pretty clean, although im going for mint, so it will all have a good clean before going back on.
ive decided to fully restore the underside, mad not to as its all out, so ive bit the bullet and purchased a rolling jig! it looks a great piece of kit, il take pics when it arrives at the end of the week, ive bought attachments for the wifes mini too so that can go on the jig once the saphs done
pics to follow
Old 22-06-2016, 03:57 PM
  #88
stu20004x4
stu20004x4's Avatar
Old 22-06-2016, 04:01 PM
  #89
stu20004x4
stu20004x4's Avatar
Default my 2wd saph restoration underway!
Old 22-06-2016, 07:15 PM
  #90
James Porter
James Porter's Avatar
I've scrapped better
Old 24-06-2016, 02:18 PM
  #91
stu20004x4
stu20004x4's Avatar
Dont lie Jimmy, you know you secretly want it!
Jig is being delivered on Tuesday folks
Old 25-06-2016, 12:38 PM
  #92
Mondi-DZK
Mondi-DZK's Avatar
Doing things right then.
Good luck with it and take your time.
Old 25-06-2016, 12:58 PM
  #93
Nice project good luck with it
Old 25-06-2016, 01:02 PM
  #94
H3lsing
ffoc.co.uk
H3lsing's Avatar
Get stuck in there matey, that's the way .
Old 25-06-2016, 02:17 PM
  #95
Nice one matey. You will have even more to clean now.
Old 03-08-2016, 06:59 AM
  #96
stu20004x4
stu20004x4's Avatar
Ive now got the interior out, and the shell mounted on the jig. Still way too heavy though, gonna have to take the doors and sunroof out I think.
Going to be spending a couple of solid days on it this week. tidied up the storage unit and built a storage floor out of scaffolding too
Old 03-08-2016, 08:52 AM
  #97
good work stu - but the jig should be able to hold the weight of the car if no running gear or interior
Old 03-08-2016, 02:06 PM
  #98
stu20004x4
stu20004x4's Avatar
Thats what I thought mate, but when I tried flipping the shell, I almost broke my arm, took everything I had to stop it spinning. A mate managed to get the pin in to stop it, but the pin started bending too! So I had to ratchet strap it back to level. I'l get some more pics of it tomorrow
Old 03-08-2016, 09:14 PM
  #99
Do you have the MK2 mania jig ?
I had the same problem and it's all about the balance point.
Use the middle hole on the angle iron cross bar to raise / set the height and use the threaded adjuster to set balance point
It will spin easily with the doors on.
Just make sure that if you take one door off, take all of them off as it screws the balance
Edit to add second pic showing a better view of jig - ignore the old git with the spray gun !
Old 04-08-2016, 11:09 AM
  #100
martysmartie
martysmartie's Avatar
Always wondered about Jigs. How do you adjust the body to get the correct angle, is it just a case of 'knocking' it into shape?
Martin
Old 04-08-2016, 01:25 PM
  #101
stu20004x4
stu20004x4's Avatar
It was a total nightmare getting the car high enough, i purchased a winding mech from the jig suppliers, what a waste of money! used an engine hoist in the end!
Old 04-08-2016, 01:43 PM
  #102
Martin
With the MK2 Mania jig, you set the balance point with the threaded bar and the angle you want to work at with a spring loaded plunger that locates in the holes drilled on the central disc.
Old 04-08-2016, 06:20 PM
  #103
Yeah i use the same jig.
I would advise not to go all the way round it might take your limbs off.
Old 10-09-2016, 05:38 PM
  #104
stu20004x4
stu20004x4's Avatar
Only a short and frustrated update, the shell is still not sitting right and is causing stress to the points where the jig is fixed. After spending all morning fucking about ive now got the maker of the jig coming down on Saturday. I jut want to crack on with the resto now!
Old 17-09-2016, 10:54 PM
  #105
stu20004x4
stu20004x4's Avatar
Well the jig Man came today, true to his word he stayed all day until we got the job done! Between us we got it set up and balanced better, made some modifications to the brackets, tested my welding skills (holy shit, I can weld!) and shes sitting pretty now.
Hell was massively top heavy still, so he even stayed to help take the doors off, which meant also stripping parts of the dash away. Got finished around 5pm, so hats off to Tom from handling solutions in Hertfordshire, top bloke! Some pics to be added. And now I can crack on ith the underside! Found some rust but im suprised at just how good a condition this shell is in! Just a bit of crut on the sills and a couple of holes
Old 18-09-2016, 10:44 AM
  #106
stu20004x4
stu20004x4's Avatar
Nothing majorly bad
Sunroof needs work
Someones had a go at restoring the rear end before me, virtually rust free, but il be stripping back anyway to make sure
Sills at the rear on their way, cn you get panels for these areas?
Hole fikked with silicon!
Nice silicon repair!
Few dents to the underside, speedbumps? Or hit jack poitioning
Old 18-09-2016, 09:19 PM
  #107
Looks nice and solid for an old Ford !
This bit is easy to fix invisibly with a steel plate after you've cut open the outer sill - do all the welds from behind and don't bother putting the random hole back in unless you are dead set on originality
stu20004x4 (18-09-2016)
Old 18-09-2016, 09:36 PM
  #108
stu20004x4
stu20004x4's Avatar
Cheers Mark, handy tip that. Not too fussed on originality, i'l see how it looks once ive cleaned it up
Old 18-09-2016, 10:15 PM
  #109
i used the same spit stu and i never trusted it tbh ,car felt too heavy for it
Old 19-09-2016, 12:43 PM
  #110
phillgti
phillgti's Avatar
cracking work, will be nice this!!
Old 19-09-2016, 01:05 PM
  #111
stu20004x4
stu20004x4's Avatar
It did mate, but the alterations we made, has really made a difference. Feels a lot more solid now. That said, I still wouldnt want to 360 it, doubt I could hold its weight still. My arms still hurting from the last time!
Cheers phill, I only plan on doing it once, so its being done right!
Old 19-09-2016, 01:10 PM
  #112
stu20004x4
stu20004x4's Avatar
This is the air gun il be using to strip the underside back. Its for single ply roofing and has digital heat control
Old 07-10-2016, 09:47 PM
  #113
stu20004x4
stu20004x4's Avatar
spent a bit of time on the car today, it seems that every time ive gone to my unit with the intention of working on the saph, i end up shifting stuff around and organising the hoard of escort and sapphire parts ive amassed! its finally looking sorted up there now, so today i got the dash out. its in really good condition for its age, but then the car is generally.
so clean!
gearbox will be next to be put on a pallet and taken for a rebuild. its a bit crunchy from 5th into 4th, sometimes needing to be slipped into 3rd first. been told its the syncro, we shall see! on the look out for an uprated gearbox if anybody sees or knows of one
engine is now on a pallet and, bar a bit of shrink wrap and carpet for protection, its ready to go the engine expert of my choice!
Thats it for now. next on the list is the loom out, then petrol tank off. ive decided to have the underside stripped back by a company called the dustless blasting co. look them up, their work is amazing! this is why i am now taking the dash and loom etc out. worth it though, and the underside will be mint once finished, i wont be doing all of this twice!
H3lsing (08-10-2016)
Old 08-10-2016, 01:43 PM
  #114
gjh
gjh's Avatar
Coming on well with you. Looks like it was in ok shape to be fair, seen much worse.
Old 18-10-2016, 08:33 PM
  #115
RSMK4TURBO
RSMK4TURBO's Avatar
Going be mint when done,good progress.
Old 19-10-2016, 06:15 PM
  #116
stu20004x4
stu20004x4's Avatar
Most of the loom is out now, just the fuse box to un bolt. Then the tank to take off, and its ready for the dustless blasting guy on the 30th. il take before and after pics of the process
Old 19-10-2016, 10:27 PM
  #117
Awesome work your doing there matey
stu20004x4 (21-10-2016)
Old 20-10-2016, 12:57 PM
  #118
Lol at the silicone bodge. At least it will get done properly this time.
Old 21-10-2016, 06:37 AM
  #119
3doorcozmess
3doorcozmess's Avatar
Hi Stu
Where you taking the engine?
There a place in croydon who done my engine. One stop shop, he does all his own machining, very good attention to detail ex clubman rally driver still has his escort group A cosworth.
You can see my build on here
https://passionford.com/forum/restor...n-its-way.html
Si
Old 30-10-2016, 03:23 PM
  #120
stu20004x4
stu20004x4's Avatar
Originally Posted by 3doorcozmess
Hi Stu
Si
Mine is going down to Colin at Supatunes, he's done work on it in the past, and others that I know too, and is a top bloke to speak to.
Your build thread is immense mate, cant wait to start putting mine back together!
Quick Reply: My 1989 RWD Sapphire Cosworth restoration underway, its on the jig!
