The Last bits off the Sierra. more parts/pics added 17/1/12
Passenger door, delocked, comes with clear glass and seals. handle parts have been removed, no door card
£40 collect only
Drivers door, same as above but has a mk6 escort door lock fitted. comes with 2 keys.
£40 collect only
Ultralight Atec 17", 7" front with 215/40/17 as new tyres. Rears are 8" wide 235/40/17 with as new tyres (wheels and tyres covered 167 miles)
£500 collect only, no offers
Pro alloy rad painted satin black.
£150 no offers can post for £15 extra
Hayward and Scott custom 3" exhaust and downpipe with V-band clamp
£350 - have reciept for £600 + VAT collect only
Stack boost gauge, 3 bar
£85 plus £5 postage
Stack Fuel level gauge
£70 plus £5 postage
fuel level on the right
Samco hose in black, 32mm i/d 63cm long £15 delivered
more samco, long is 27.5cm, short 9cm. £7 delivered
SFS 90 degree bend and 2 joiners 7cm long £12 delivered for those 3
90 degree plastic hose joiners x4 32mm. £10 delivered for all 4
11x 25-40mm hose clips £10 delivered for all 11
-12 90 degree fitting with oil hose 69cm long. hose ID is about 15/16mm £8 delivered
-12 straight fitting with oil hose 99cm long £8 delivered
-12 45 degree to straight coupling oil hose 56cm long £12 delivered
-12 45 degree with short oil hose23cm long £7 delivered
-3 goodridge ptfe braided hose, straight fitting one end, 90 degree the other £9 delivered
burton power brake bias pedal adjuster, unused 90cm long cable £18 delivered
2wd cosworth T5 speedo drive £65 delivered
MSD thermostat switch used for 167 miles £10 delivered
revotec sump plug adaptor m14 thread with 1/8npt hole tapped in for a sensor £12 delivered
heat sheild 300mm x 300mm, dropped on one corner
£20 delivered
9x 1" rubber coated alloy P clips £10 delivered
20x 13mm rubber coated alloy P clips £12 delivered (suiable for -6 fuel hose)
18x 8mm rubber coated alloy P clips £12 delivered (suitable for -3 brake hose)
pro alloy made solid hose in black, has a -8 take off, 32mm ends £15 delivered
pro alloy made kinked hard pipe boost hose 65mm i/d £20 delivered
pro alloy made hard pipe boost hose, 55mm i/d £20 delivered
if i find anything else, ill stick it up.
all postage will be citylink express 24h
07876207885
Cheers, Dan
£40 collect only
£40 collect only
£85 plus £5 postage
£70 plus £5 postage
£20 delivered
07876207885
Cheers, Dan
core is 60mm, n/s inlet is 65mm, o/s inlet is 77mm.
i bet even if you sent the rad back to pro alloy to mod it would still be cheaper than buying a new one
ic was £450, rad £250
no, i sold on ebay beef... £0.99p!
and the fucking cunt still moaned about the box being damaged by the courrier when he got it!
i just remembered i have a load of stack stuff ill add.
and the solicitors have a copy of the police report now, but its all gone quiet on their part really....
the orange fire proof stuff or the silver heat proof stuff?
as i have some of both lol
dixie, pm me if you like, you obviously have a maximum you can go to, so try me
yes mate, and white
[QUOTE=jonfoc;5773586]
will sort out pics later bud
yes, i still have it. will measure when i get home
