Cosworth bits & bobs
payment by paypal (GIFT), cheque or cash - all prices are posted
Escort Cosworth lambda sensor in perfect working condition - £32.00
Blue silicon hose Brand new 2wd - header tank to Turbo hose - water pump to metal water pipe hose - thermostat housing to Turbo hose - £20.00
4x4 Sapphire & Escort Cosworth dip stick brand new bought by mistake - £16.00
SFS silicon hose TB - Intercooler hose inc DV - standard Cosworth size, very good condition - £20.00
MSD cam spacer for using 4x4 cam in 2wd head - £6.00
Goodridge AN4 90 degree teflon fitting in silver - £8.00
Goodridge AN3 - 1/8 BSP adapter - £3.50
Brand new Head bolts (for Early type 3dr Cosworth with small 21.5mm washer) £27.50
Std 2wd Exhaust cam BD08 spec good lobes - £30.00
Cosworth aftermarket breather fitting inlet side (removes kidney box) - £10.00
Cosworth Genuine big end bolts - £15.00
Cosworth little end rod bearings brand new 1/2 price - £25.00
Coil bracket - £7.00
Cometic reusable gaskets inlet manifold gasket and the turbo gasket is a metal item not the poor material one that breaks up - were used on the last engine but did less than 900 miles - ok reusable condition - £12.00
Cosworth PAS cooler pipe - with all screws and bracket - £17.50
It's the standard adapter that comes on the car that the oil feed and the sensor screw in to
the bells is off a GrpA car and has asphalt written on it - not sure on the materiel but it's light.
Has been fitted to a 330mm rotor in the past - depth is 25mm
what i will do is get sizes and post them up - it's a cheap way to get a set of bells as you would just need someone to knock you one up identical
Sold to you
Sold to you
wont really know for sure until the engine and ancilliaries are being built up (which hopefully will be within a few weeks time)
Header tank, not sure as I never bothered as mine goes into a turbo cooler so pipe sizes step down in size
Brammer is this the oil pressure gauge adaptor mate?
If it is send us your PayPal details
Cheers gaz
http://www.burtonpower.com/lma011.html
Cheers gaz
