BREAKING 2wd sapphire, BUY BUY BUY my shonky ford parts!
Old Aug 26, 2010 | 07:10 PM
Mr.worth's Avatar
Mr.worth
Default BREAKING 2wd sapphire, BUY BUY BUY my shonky ford parts!
Ill start with the shell, Ive owned the car for 8 years, its White, loads of history, always garaged, not concourse but not bad, chassis legs have very minimal surface rust, has had a couple of bits sorted out inside footwell and around passenger seat mount, I did start to crack on with underbody resto but then gave up due to other cars! will get pics at the weekend, rear drivers door gone at the bottom, slight dink on n/s wing where a head light fell of the shelf onto it (its not bad though). This will come with all doors glass, boot and bonnet, it wont be rolling, £500
Engine,
200 block built by bluesprint done 10k
Balanced bottom end with shot peened rods
Proper long stud conversion
WRC Headgasket
Forged pistons
7:5:1
Ported 2wd head
BD10 cam
Isky valve springs
Vernier pulleys
Polished inlet manifold
comes with all sensors attached.....£1999 Collection only!
Here goes all the other bits bear with me I do expect to be very busy from this lol, all plus postage or collection, started stripping the car today so most bits are avalible and ready for packaging.
Saftey Device Rollcage from a 3dr does fit the saff £250 Collection only! SOLD
Alloy Incar fuel tank £250 SOLD
Air Injectors and wiring harness £200 SOLD
Siemens black injectors 83lb ones £180 SOLD
Side Exit Exhaust, goes straight to 4" off turbo x2 lamba sensor/gauge ready, upswept tail, very very loud, has been restricted inside for some back pressure £400 Collection only! SOLD
L8 ecu with msd closed loop chip for spec im selling £300 SOLD
Pace alloy rad £60 SOLD
Bosch 044 fuel pump and fitting £100 SOLD
Universal Turbos T34/T38 43 housing only 600 miles, -31 and black samco hose for air filter £600 SOLD
17" Ultralite 789's Mint!with Lightweight nuts, will check what tyres are on them I know they're legal if that helps £350 SOLD
Ap 6 paddle clutch and Alcon cover (best combo IMO) Less than 1000 miles £250 SOLD
Ap racing 4pots,Brackets discs and green stuff pads Hardly used £850 SOLD
2wd Rear calipers, grooved discs, good pads £150 painted black
Front and Rear Bumpers, Front has toe eye part cut out VGC £150 for the pair including fogs and surrounds Collection only!
RS500 Fibreglass style splitter £80 Collection only!
2wd Beam and driveshafts hubs and polybushed arb £80 Collection only!
Standard Headlights £30
Morette twin headlights £200 SOLD
Bailey turbo damper £80 SOLD
Boot sponge and carpet £25
Sideskirts £40
GearBox Bellhousing £40 SOLD
2wd Fuel pressure reg £25 SOLD
2wd Exhaust manifold £50
2wd dark dash top part £50
New clutch cable £10 SOLD
Spec R rear strut brace £80
Ahmed Uprated Lowering Springs, these are brand new! £130 SOLD
Rear Brake disc gaurds, these are new £25 SOLD
Smoked rear lights £50
Bailey oil seperator £60 SOLD
Pace swirl pot £40 SOLD
Pace header tank £80 SOLD
3 bar map sensor £40 SOLD
GRP A coil £15 SOLD
RS engraved bonnet raisers £20
2wd Steering rack £100
Uprated Diff mount £100 SOLD
Carbon fibre battery holder, this is a one off! £15 SOLD
Carbon fibre dump valve plug £15
Carbon fibre rear door quarter bits £50 SOLD
Motorsport HT Leads and dizzy cap £50 SOLD
Ignition amplifier £25
Glebe Straightcut DOGBOX, 50 miles £1999
Gripper diff (not quiafe) New in powdercoated casing with zinc plated bolts standard ratios £999
Rear diff gaurd, powdercoated black £80
New Reconditioned Driveshafts ready to go £120 SOLD
GRP A Front hubs New£70
Engine loom £70 SOLD
2wd clocks £25
Bailey PAS tank £65 SOLD
Front ARB with poly bushes £30
K&n Air filter £50 SOLD
Koni/Bilstein Shocks with Chassis dynamic springs £200 SOLD
RS 3 spoke steering wheel push horn and RS boss £180
Alternator £30
Propshaft £50
Bosch 044 fuel pump bracket, brand new still boxed £40 SOLD
ISCV £25 SOLD
Carbon 3 gauge holder for dash £15 SOLD
Oil pressure gauge electrical stepper type, not cheap ebay tat, face had a few marks £35
AutoMeter Air fuel ratio gauge + fitting kit £80 SOLD
Ignition amplififer and bracket £25
Mocal oil pressure gauge, electrical type "25
Samco hoses for water X2 £40 SOLD
Samco hoses for boost X2 £45 SOLD
Sabelt harness, needs a clean £20
Inlet temp gauge, digital type £20 SOLD
Magnetic sump plug for Nissan skyline £5
Cosworth grill, one broken clip £15
Starter motor £50 posted
Will update with pics asap,
Probably missed loads so ask just incase I have what you need
My number 07525774987
Old Aug 26, 2010 | 07:38 PM
J1mbo's Avatar
J1mbo
B1mbo
Can I have a pic of front splitter please and would you post ? Can email me the pics at Jim_Gibbs@hotmail.co.uk or pm me on here ! Cheers
Ps pic of header tank would be good too
Old Aug 26, 2010 | 07:57 PM
Craig J's Avatar
Craig J
Hi, Could you tell me what is unique about the Group A front hubs and driveshafts please? Thanks, Craig
Old Aug 26, 2010 | 08:24 PM
turbocat's Avatar
turbocat
Martin WHAT ARE YOU DOING
I can back this engine its 100% genuine. Such a shame mate have you gone skyline mad
Old Aug 26, 2010 | 08:36 PM
panosrc's Avatar
panosrc
Hi can I have a pic of the Gra hubs?
Old Aug 26, 2010 | 09:09 PM
cossieclive's Avatar
cossieclive
im interested in the bonnet lifters, boot carpet and carbon door quarters, but will need to check how much i get on pay day!!
Old Aug 26, 2010 | 11:20 PM
Jase-G22TMJ's Avatar
Jase-G22TMJ
Cosworth, enough said!
I've been in this car last time it was on the road....... the motor is A1 and fvck mr does I go!
Old Aug 27, 2010 | 04:41 PM
Mr.worth's Avatar
Mr.worth
Pics of requested parts and a few extra , Please note all polished parts will need a polish
Old Aug 27, 2010 | 04:44 PM
bad boy rs's Avatar
bad boy rs
Hello mate i will take the rear brake cover things please, can you pm me payment details
Old Aug 27, 2010 | 05:14 PM
Mr.worth's Avatar
Mr.worth
Hi mate, sorry you were about 30seconds too late
Be quick peoples
Old Aug 27, 2010 | 07:29 PM
Mr.worth's Avatar
Mr.worth
Just to add, the Doors have mint window rubbers and the shell is an ex press car used by ford, there's a riveted plate on the slam panel that says no manufactures warranty, Alain no rot inside rear arches and all sound deadening has been removed, all the hard works done underneath ready for resto, inside bootlid is also mint, engines coming out tomorrow so will get pics of good and bad bits on the shell, could really do with it gone as it takes up loads of space!
Old Aug 27, 2010 | 07:40 PM
J1mbo's Avatar
J1mbo
B1mbo
Can I have a picky of splitter please bud ! Jim
Old Aug 27, 2010 | 07:55 PM
Mr.worth's Avatar
Mr.worth
Haven't forgot you mate, the cars wedged right up to the workbench and on axle stands, engines coming out tomorrow so I'll try ang get it off
Old Aug 27, 2010 | 08:01 PM
AJC's Avatar
AJC
What have the shafts had done to them? 2wd shafts? Also, will you post
Old Aug 27, 2010 | 08:18 PM
J1mbo's Avatar
J1mbo
B1mbo
Thanks matey mucho appreciated
Old Aug 27, 2010 | 08:22 PM
Mr.worth's Avatar
Mr.worth
They have been reconditioned by a place in dorset who traded on ebay,...tg motorsport rings a bell?, dont know if they're still around but they had an immaculate workshop and break rally cars so could be stronger? im sure there was a reason I bought them, anyway they're powdercoated and zinc plated with new boots, for 2wd and ive had them for a couple years now.
Old Aug 27, 2010 | 10:25 PM
c20tbo's Avatar
c20tbo
Pm'd
Old Aug 28, 2010 | 06:34 AM
snoopaloopa's Avatar
snoopaloopa
Aslo known as TG_91 iirc
Old Aug 28, 2010 | 08:38 AM
Mr.worth's Avatar
Mr.worth
That's the boys!!, they built the diff, and I got the hubs off them too, I was like a kid in a candy shop I their container.
Old Aug 28, 2010 | 01:39 PM
saph in dorset's Avatar
saph in dorset
would be interested in the uprater diff mount if you still have it??
let me know what the postage would be as well to Poole, BH16 5JJ
thanks adam
Old Aug 28, 2010 | 07:19 PM
jay991's Avatar
jay991
just tryed to give you a ring if you were wonering about the stange number, have you got a good set of dark door cards by chance?
Old Aug 28, 2010 | 08:04 PM
Rob Virgo's Avatar
Rob Virgo
any secs monitor lad
rob
Old Aug 28, 2010 | 09:44 PM
Mr.worth's Avatar
Mr.worth
Sorry mate no door cards
Rob,
No secs im afraid.
Old Aug 28, 2010 | 10:10 PM
AJC's Avatar
AJC
Will you post those shafts then matey? Ta
Old Aug 29, 2010 | 08:38 AM
Rob Virgo's Avatar
Rob Virgo
Wink
Rob,
No secs im afraid.
thks but you should get a girlfriend maybe.......lol
couldnt resist
Old Aug 29, 2010 | 09:18 AM
Mr.worth's Avatar
Mr.worth
AJC, sorry mate they've sold,
I can send anything anywhere, im spreading the car all over the world as we speak
Rob,
Stop trying to offer me money for secs mate
Old Aug 29, 2010 | 10:38 AM
Mr.worth's Avatar
Mr.worth
Todays Treasure,
Old Sep 3, 2010 | 04:50 PM
Mr.worth's Avatar
Mr.worth
Someone buy my shell before I cut it into little peices
Old Sep 3, 2010 | 05:13 PM
turbocat's Avatar
turbocat
Stick it on ebay Mart If I get 5 mins tomoz I will pop up
Old Sep 3, 2010 | 08:47 PM
1300gt's Avatar
1300gt
Interested in sytec pump mounting. Pm me best del price please
Old Sep 5, 2010 | 09:09 PM
1300gt's Avatar
1300gt
Default Pump mount
Paypal coming your way mate. I will take the black pump mount .
Old Sep 5, 2010 | 09:11 PM
J1mbo's Avatar
J1mbo
B1mbo
Have you had any chance to take picky of splitter yet bud ?
Old Sep 6, 2010 | 02:30 PM
Mr.worth's Avatar
Mr.worth
Its still on the car im afraid, thinking about it im not to sure I want to post it, its only fibreglass and couriers dont give a shit
As soon as its off I'll get a pic, havent got round to getting the engine out yet as nobodys intrested in it or the shell so they can stay where they are for now,so front bumper and splitter are stuck about a mm away from the workbench
Old Sep 6, 2010 | 04:18 PM
cossie891's Avatar
cossie891
Mate I need front door panel screws and all the screws/bolts in the bay also a drivers window motor
Old Sep 6, 2010 | 05:58 PM
mulla's Avatar
mulla
recived springs today was very happy thanks again
Old Sep 6, 2010 | 08:05 PM
J1mbo's Avatar
J1mbo
B1mbo
No probs mate !
Old Sep 6, 2010 | 08:10 PM
Mk4 Lew's Avatar
Mk4 Lew
might seem a bit stupid but badges ??
Old Sep 6, 2010 | 08:43 PM
ram's Avatar
ram
Has a large member
Doh! the 6paddle was still for sale yesterday. why did i wait lol. pm'd regarding black boost hoses
Old Sep 6, 2010 | 08:55 PM
Mr.worth's Avatar
Mr.worth
Badges are going with boot and shell at the moment, if the shell doesn't go then boot and doors ect will be sold seprate
Old Sep 6, 2010 | 10:19 PM
Mk4 Lew's Avatar
Mk4 Lew
ok mate
