Garage Clearout (eBay's now had most of it...)
Final few bits left over now. Most are already in the 'tip' pile tbh...
-Headlight wiper motors. Complete with both blades and all fixings, in good condition. Offers
-Std inlet cam, may have pulley still £20.00
-Fuel Vapour Valve, broken lug. £2.50
-Main Alternator drop bracket, elongated long bolt lugs but may be of some use to someone to fill and redrill. £5.00
-PAS std tank (lower one in pic). £10.00
-Hard pipes; FPR vacuum and std dump valve vacuum I think. Offers
-Damaged late 2wd head. Has a crack between spark plug and valve on both No. 2 and 3, measuring 138.0mm. Open to offers.
-Turbo oil drain pipe £5.00
-2wd Cam bearings and shims, used. £5.00
-4x4 cam bearings, used £5.00
-Used cambelt £5.00
-Various valve springs, retainers, collets etc. Offers
-Used 071 plugs £10.00
-Lots of old tappets... Offers
-Long driveshaft, one joint's on it's way out £10.00
-Std rear spring seats in pretty good nick £10.00
-Pair of springs measuring 130mm x 270mm £5.00
-Old top mounts, bearings and nuts £5.00
-N/S TCA (split rubber) £5.00
-Fog light spares... various fog light lenses and inners in lesser condition.
-N/S headlight with one chip, £10.00
-4x4 Fuel Flap, was a magenta one which has been DIY sprayed Diamond White, could do with redoing or doing properly. £10.00
-Scuttle panel, in good condition apart from one broken lug (n/s front) £10.00
-N/S rear and O/S front window rubbers. I replaced them with mint ones but could be reused if you're not too fussy (just some splitting inside a couple of corners) £5.00each
-Reg plate lights. One is missing outer casing, maybe of some use to someone. £2.50
-Wiper motor £10.00
-Chassis Bumper Mounts £5.00
-Used handbrake cable, £5.00
-Universal push fit fuel cap £2.50
-Grey A-Pillar £10.00
-Faded front window switches £2.50
-Clock surround with hole drilled for LED etc £5.00
-Cassette holder (2pc console) x2. £2.50each
-Cassette holder (1pc console) £2.50
-Clarion lower dash speaker and mounting plate £5.00
-Additional Indication Warning System module bracket with one broken lug £2.50
-Centre console hinge £1.00
-Boot hinge spring £2.50
-Various hoses inc ally T-pieces, washer tubing etc (No red silicon hosing or top t-piece)
-ERST speaker balance adjust knob, £5.00
-Bonnet stay. Is about 3" shorter than a Cosworth one, possibly ERST? £5.00
-Brand new JBL GTO speaker covers for 6x9s and 13cm speakers £10.00 a pair ONLY 13cm LEFT
-Used cambelt £5.00
-Wiper motor £10.00
All pm's answered so far and thread edited to clarify a couple of things re ACT gauge and clutch. Will be getting more pics tomorrow morning and to weigh the larger heavier items (flywheel, clutch etc) for accurate postage quotes.
corsa-xe1 - I was wanting to leave the turbos as complete as possible ideally so make me a good offer on the bracket and i'll sling a turbo in for nothing!!!
RSCossieGaz - I'm not really sure what they're worth tbh, that's why I'm open to offers. Try me... you may be surprised!
I'll be getting some better pics in the morning anyway to show their condition...
Hello mate is the clutch sold yet?! Also the gasket set does it have the oil cooler seal in it?! Also do you have a normal fuel pump cradle?! Plus need a set of 2wd discs if u have any kicking about, only in worthing too so wont need anything posting!!
Tony
Tony
Christ... this got dug up from the depths!
Yep... most of it's gone now but completely forgot to update this thread!
I'll have a clearup in a minute... can't even remember what i have got left, useless!
Def no crank, red pipes and arch liners.
Joe... let me know what bits you might need. And if you're in West Sussex why haven't you made an appearance on www.wsrsoc.co.uk ?
I've been invited a few times but with one thing and another (moving house & work!!) I havent found the time. I will try, promise
rsguy
44
Sep 29, 2015 03:29 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
