Breaking good spec 4x4 sapphire. Smokestone.
HAD A GUY PULL OUT OF BUYING LOTS OF BITS SO SOME STUFF IS GOING BACK ON THE LIST. IT WILL BE HIGHLIGHTED IN GREEN. CHEERS.
FULL LEATHER INTERIOR WITH DOOR CARDS IN GOOD CONDITION £300
4X4 ENGINE LOOM SOLD
ABS ECU
STEERING COLUMN
HEAD LINING WITH NO SAGS SOLD
CARPET SOLD
INTERIOR PLASICS
REAR SHELF AND SPEAKERS SOLD
SEAT BELTS SOLD
ALTERNATOR £20
STARTER MOTOR £20
CLUTCH AND COVER UPRATED
BOOT CARPET AND SPONGE BIT SOLD
BOOT CARPET SHAPED SIDES £10 EACH
FRONT BUMPER WITH GENIUNE RS500 SPLITTER FITTED SOLD
MORRETTE HEAD LIGHTS. SOLD
REAR BUMPER SOLD
FULL STAINLESS EXHAUST EXCELLENT CONDITION. SOLD
AP RACING 330MM FRONT BRAKES ROTORS & PADS LESS THAN 1000 MILES!SOLD
REAR VENTED STANDARD DISKS AND CALLIPERS £125
ELECTRIC SUNROOF KIT £60
RS COSWORTH STAINLESS SILL PLATES £22
VENTED BONNET SOLD
FRONT GRILL £15
STRIP UNDER HEADLIGHTS NO WASHER CUT OUTS! SOLD
FULL AIR CON SETUP SOLD
REAR SMOKED LENSES SOLD
NUMBER PLATE SURROUND SOLD
CLEAR FRONT INDICATORS £5
CLEAR SIDE REPEATERS £5 DELIVERED
turbosystems breather sold
ALLOY HEADER TANK IN RED SOLD
STANDARD ORANGE HOSE FROM TURBO BOTTOM PIPE TO INTERCOOLER £5
BLUE SILICON HOSE FROM T35 TURBO TO GROUP A K&N FILTER SOLD
4X4 INTERCOOLER WITH DENT BUT NO HOLES £15
RADIATOR NO FANS SOLD
FANS FOR RADIATOR SOLD
TURBO HEAT SHIELD SOLD
DUMP VALVE IN SILVER SOLD
STEERING WHEEL. 2WD IN GOOD CONDITION SOLD
TURBOSYSTEMS BOOST GAUGE / PIPES £20
RACETECH GAUGE OIL PRESSURE WITH FITTINGS £25
TWIN SURROUND GAUGE HOLDER FOR UNDER STEREO £10
CLOCKS WITH 87000 MILES ON SOLD
BLACK FLOOR MATS X4 SOLD
BLACK DASH WITH 2 ALARM LIGHT FITTING HOLES SOLD
4X4 GEAR BOX A BIT noisey on tickover but arnt they all lol. G.W.O £200
REAR DIFF SOLD
FRONT DIFF £40
FRONT SHAFTS SOLD
INLET MANIFOLD SOLD
4X4 FUEL RAIL AND REG SOLD
REAR SHAFTS £50
STRUT BRACE SOLD
REAR BEAM WITH POWERFLEX BUSHES. NO ARMS £30
KONI ADJUSTABLES WITH LESS THAN 1000K MILES FRONT/REAR SOLD
UPRATED SPRINGS X4 £20 UNSURE OF SPEC. FREE WITH THE KONIS.SOLD
L8 ECU SOLD
L8 TURBOSYSTEMS CHIP TO RUN LOW COMP, 4 X GREYS, T35 £ 30
2WD EXHAUST MANIFOLD NO CRACKS £40
T35 TURBO TECHNICS BLOWER. LESS THAN 1000 MILES. S112. SOLD
STEERING RACK £30
ALLY ENGINE SUB FRAME £25
STANDARD ENGINE MOUNTS £10
GEARBOX DUST PLATE £10
FRONT AND REAR ANTI ROLL BAR £20 EACH
DIZZY,SENSORS, FORD MOTORSPORT BLUE PLUG LEADS SOLD,COIL,FRONT AND REAR BEARING CARRIERS/HUBS £10 EACH. DRIVE SHAFT FLANGES £10 EACH
STILL MORE STUFF LEFT. JUST ASK
ALL PRICES PLUS DELIVERY. JUST ASK OR MAKE ME AN OFFER.
SHELL IS AVAILABLE WHEN STRIPPED AND HAS VERY LITTLE RUST ETC. ITS A VERY LATE K PLATE 11/05/1993! WOULD MAKE A GOOD RESHELL. SOLD
TURBOSYSTEMS ENGINE. 7.2.1, GROUP A PISTONS 0.25, NEW SHELLS, OIL PUMP, WRC HEAD GASKET, HEAD PORTED TO 450BHP SPEC BUT WAS RUNNING 400. SUMP WINDAGE TRAY, 200 BLOCK, POWDER COATED ROCKER. THIS IS A FAST ENGINE TO DROP STRAIGHT INTO ANY COSWORTH TO SAVE A REBUILD ON YOUR OWN ENGINE! MORE DETAILS ON REQUEST. £2700 ono. ONLY 17000 MILES SINCE REBUILD IN 1999.
LOADS MORE BITS JUST ASK! DISCOUNT FOR MUTIPLE PURCHASES! I HAVE LOTS OF PICS, JUST ASK!
adamatecs@hotmail.com pm me, text or call 07968545399
IF YOU ARE A MESSER OR JUST GENERALLY DREAM ABOUT PARTS YOU CANT AFFORD, PLEASE DONT BOTHER ENQUIRING AS IM GETTING FED UP WITH TIME WASTERS. YOU IDIOTS KNOW WHO YOU ARE.
ABS ECU
STEERING COLUMN
CARPET SOLD
INTERIOR PLASICS
SEAT BELTS SOLD
ALTERNATOR £20
STARTER MOTOR £20
REAR BUMPER SOLD
VENTED BONNET SOLD
FRONT GRILL £15
REAR DIFF SOLD
FRONT DIFF £40
FRONT SHAFTS SOLD
INLET MANIFOLD SOLD
REAR SHAFTS £50
STRUT BRACE SOLD
L8 ECU SOLD
STEERING RACK £30
im at burton on trent mate. its a good shell. how much of the car would you want? its pretty much together at the minute with doors, bonnet, bumpers etc.
let me know via pm please.
but please dont mess me about and confirm to me as soon as you can when you can take them.
cheers.
