Austin metro pictures added
Old Sep 3, 2017 | 04:17 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
lets face it as a car theyre crap, they were crap in their day and rose tinted specs don't make them any better
but as a low mileage original collectors item and money making bargain its a great find. id do no more than getting it running reliably and cleaning it up a bit then look to see about getting it valued via an owners/enthusiasts club that theres bound to be for them. such a low mileage original examples bound to fetch several times what you've paid for it.
a quick ebay search shows a similar 45000 miler up for Ł3500.
Old Sep 3, 2017 | 10:32 PM
Make sure the dash pot on top of the carb is filled with oil as that'll cause a lot of running problems. It just unscrews (black cap) on top of carb and is a piston/plunger on a rod, make sure that's filled up with oil otherwise it won't run properly if at all
Old Sep 3, 2017 | 10:39 PM
mk1turboestate's Avatar
mk1turboestate
Does it need filling to the top with oil or just a little? Also what oil does it take? Thanks for the advice
Old Sep 4, 2017 | 08:43 AM
Thats well cool.
I seen a metrot mg yesterday.
Old Sep 4, 2017 | 01:06 PM
To be honest mate it's been so long since I worked on one I can't 100% remember correctly but I defo used to use 10w40 or 15w40 (whatever we had in the workshop) and used to fill it up most of the way to the top and push the plunger back in and then if there was too much it would just come out the sides and never caused a prob.
Old Sep 4, 2017 | 03:08 PM
massivewangers's Avatar
massivewangers
Originally Posted by Glenn_
Thats well cool.
My mum used to have a silver MG Metro. Said it was the worst car she had ever owned
This looks a real time warp job. I'd get it cleaned up and just sit on it. I bet a collector would pay reasonable money for it. Could turn a tidy profit I reckon.
Old Sep 4, 2017 | 06:19 PM
I had a silver mg metro, I thought the red seat belts are carpets were sooo cool lol, I killed it trying to do a burnout in front of my mates, reversed back, first gear, clutch and revs up then a bang so loud half the neighbours came out
Old Sep 4, 2017 | 07:45 PM
mk1turboestate
This is the płan, small Resto on the worst bits and run it to a few shows, I paid so little and have the space I will sit on it for the foreseeable
Old Sep 4, 2017 | 07:46 PM
mk1turboestate
Cheers. I will have a go ones the new fuel pump arrives
Old Sep 5, 2017 | 07:29 PM
mk1turboestate
So the new fuel pump arrived today! On it went and started straight up, it seems like it has a bit of a misfire so I will check the leads dizzy etc tomorrow and may well order some new vac hoses and see if that solves it,
Iv also rubbed down some surface rust on the front ready to prep and repaint.
Does anyone know where to find the paint code for the metal bumpers? I can find the main paint just not the bumpers
Old Sep 27, 2017 | 08:21 PM
mk1turboestate
Few updates on the car, iv decided to keep it off the road now this winter and sort out the few issues it has. I intend on keeping it as original as possible so don't want to swap panels for no reason but iv had to sort a new valance for it, I found a mint front end at a breakers so cut the front off and will use part repair panels as shown in the pics.
First up I cut the rot from the drivers wing
I then cut a repair panel and welded it in place
I then removed the front panel and found a small repair under the drivers headlight is required and a small repair to the crossmember also, the crossmember was done then hammerite was added for protection, it will be all wax oiled when its done also.
I have also patched the headlight surround now with a repair section but no pics of that yet
Old Sep 27, 2017 | 10:36 PM
slammedorion's Avatar
slammedorion
Getting stuck in there and being done properly
Nice
Old Sep 27, 2017 | 10:43 PM
thats a lovely bit of history you got there mate
Old Sep 28, 2017 | 07:54 AM
Rescuing it too.
Worth checking where the subframe meets the body in the rear wheel arch (sort of where the back seats are) as they can rot there.
Old Sep 29, 2017 | 09:26 AM
anthony lea's Avatar
anthony lea
Ford allegiance
Lovely condition!
Always wanted to have a go of a Metro (and an original Mini too)...
Old Sep 29, 2017 | 10:14 AM
Originally Posted by anthony lea
Lovely condition!
They are great for todays roads...they have more power than grip (and not a lot of power) and you can play around with lift off oversteer, understeer and 4 wheel drfits all at a speed lower than the speed limit.
Old Sep 29, 2017 | 07:29 PM
mk1turboestate
Thanks for all the positive comments, as you can see I'm ending up giving it a minor resto, wings off etc, I will check all areas for corrosion, it's only ever had one patch in the past and I'm not happy with it so will cut out and re do it. I'm not using full panels because it doesn't really need it and I want to keep as original as possible
Old Sep 30, 2017 | 04:20 AM
Good bodywork repairs your doing.
Old Sep 30, 2017 | 11:02 AM
Minion-Steve's Avatar
Minion-Steve
Looks nice , time warp car
Old Sep 30, 2017 | 11:38 AM
mk1turboestate
Just to add a couple of pics of the headlight repair section, I bought a complete cut off front end so all the parts are genuine perfect fit. I need to flap disc some of the welds and stone chip so it looks original but there is very little rust I would just prefer to cut out anything so it lasts another 30 years, the purple crap is rust remover just in case
Next I need to remove the passenger wing to check behind it and I need to source a wing also to replace my bottom section.
It's possibly on hold for a while now because our new kitchen was delivered and needs fitting
Old Sep 30, 2017 | 07:27 PM
Very impressive work matey
Old Oct 1, 2017 | 09:23 AM
studabear's Avatar
studabear
Well done on saving it, I used to hate them as a apprentice but I enjoy seeing them now!
Is it still on 160/65/315 tyres? Last time I looked at work we couldn't get them anymore.
Old Oct 1, 2017 | 09:32 AM
mk1turboestate
Cheers and yes it’s still on the metric wheels and needs tyres, because it’s so original I’d like to replace like for like but I may need to change the wheels
Old Jul 10, 2019 | 06:47 PM
mk1turboestate
So i have been back on it again! Needed a passenger wing in the end and minor repairs behind the wing but other than block sanding the wings and valance, and a small amount of filler on the drivers sill it’s almost ready for paint,
I’m not looking forward to the paint match with it being red but I will see how it goes.
Old Jul 10, 2019 | 07:59 PM
Coming on well
Old Jul 10, 2019 | 10:28 PM
Keep seeing the odd metro turbo for sale on Facebook. Some really clean ones! Cool little retro car now
Old Jul 11, 2019 | 12:53 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
That might be a "goldseal" engine as the factory returned engines and painted them gold. That may mean it can run unleaded.
The engine is the correct colour for an original 1000cc A+
Old Jul 11, 2019 | 06:39 PM
studabear's Avatar
studabear
1000cc yellow 1300cc red
Old Sep 20, 2019 | 07:52 PM
mk1turboestate
No major updates on the car but I feel in somewhat of a dilemma. My intentions were always to keep the car as original as possible but for the first time in ages I called into a local car meet and a mate of mine took me for a quick spin in a rover metro with a lotus Elise in-line in it and f..k me that was quick! So quick that someone else took it out and a rather nice Porsche ended up in the pub car park to see what was under the bonnet because he got shit all over off the lights.
So as you can imagine my dilemma is do I stay standard or do I go k series?
Opinions wanted
Old Sep 20, 2019 | 08:41 PM
Better engine but standard exterior...that would be great.
Old Sep 20, 2019 | 09:22 PM
mk1turboestate
Thats is my thoughts, on eBay looking for a mg tf at the moment
Old Sep 21, 2019 | 03:33 PM
thebigmacmoomin's Avatar
thebigmacmoomin
Keep it original, not going to be many around now espically in good condition, lots of history & low mileage.
If you want to build an pocket rocket sleeper, buy another one.
Old Sep 21, 2019 | 06:16 PM
mk1turboestate
I get get your point but I don’t need two,
i think I need to get it on the road and I am on the look out for a 160 tf if one comes up cheap,
i do need to do more research into how the k series mounts in the Austin because I don’t want to cut it up
Old Sep 22, 2019 | 12:40 PM
mk1turboestate
After some research I have found that in order to fit the k series I would need to cut the inner wings and the chassis rails, I really don’t want to do it to this car so it’s a no go
Old Sep 22, 2019 | 12:45 PM
How about an Avonbar 1380 big bore, head work and decent cams? 100+ bhp is not hard. The David Vizard book, "tuning the a series" is old but well worth a ready.
Old May 27, 2020 | 09:23 AM
mk1turboestate
Well, I have been back on the metro and decided to do a restoration series on it, I’m very new to YouTube so if you watch and have any hints or tips how I could improve please let me know,
more footage, less etc,
if your interested in the project please subscribe
Old May 27, 2020 | 02:02 PM
If you want some inspiration with a ford twist I will leave this here
now turbo charged.
A really nice chap that gave me a few leads with my project.
Just imagine that behind your left ear in a metro ........... of course it makes sense
Old May 31, 2020 | 06:34 PM
mk1turboestate
I’m upto part 5 in the restoration now, things have got out of hand
Old May 31, 2020 | 09:21 PM
studabear's Avatar
studabear
Aye it's well stripped down now like.
Old May 31, 2020 | 09:25 PM
mk1turboestate
Got one on me didn’t I, I will be glad at the end when it’s done.. the way I looked at it a few extra hours makes the difference to the end result,,
when the metro is finished my cabby is going RWD
