Expansion tank.
There's one on eBay around £80 but it's not new, I'd have thought you'd be looking at a few hundred at least for a new one, even then it's an old plastic bottle that's been stored, personally wouldn't have one on my car as I've had one split
Ford haven't sold the original 2wd header tank since the early 90's.
The only one you can buy new is the 4x4 one which does not have the same pipe connections or the level sensor hole.
Most (if not all) 2nd hand ones will have some crazing around the level sensor hole and pipe connectors.
