Saph cos susp/underbody resto..*Update 16/04,on road*
Couple of things I've done so far with my car in hibernation :top:
New steering rack,engine mounts,steering linkage,adjustable TCA's,wheel bearings,Konis,Eibach springs :cool: https://img.photobucket.com/albums/v...r/100_0145.jpg https://img.photobucket.com/albums/v...r/100_0146.jpg https://img.photobucket.com/albums/v...r/100_0144.jpg https://img.photobucket.com/albums/v...r/100_0148.jpg https://img.photobucket.com/albums/v...r/100_0147.jpg https://img.photobucket.com/albums/v...r/100_0149.jpg |
quality kev,looks minty under there ;),what engine mounts are you using out of intrest?
Just standard new eng mounts,the old ones were well fooked,picked up a pair of new ones for £20 :cool: Ford wanted £50 each :eek: :) |
Where did you get your rack and how much,, mines got a bit of play in it...
And have you put new koni's on or had them powder coated?! Looks v.nice :top: |
Oh yes, very nice :top: :clap:
And have you put new koni's on or had them powder coated?! Looks v.nice :top: The seller was advertising them on there every week,was a few months ago though.I'll find his user ID if I can and PM it to you :top: Konis were bought second hand,only done a couple of months on road,I sprayed them with some Sunset yellow paint from Wilkos! :DD: :top: |
And have you put new koni's on or had them powder coated?! Looks v.nice :top: The seller was advertising them on there every week,was a few months ago though.I'll find his user ID if I can and PM it to you :top: Konis were bought second hand,only done a couple of months on road,I sprayed them with some Sunset yellow paint from Wilkos! :DD: :top: Wilko's?? Where's that... may as well paint my fronts before they go on, my rears are brand new.. https://img.photobucket.com/albums/v...HarveySaph.jpg |
Very nice Kev! Top work :top: :top: :top:
Cheers all :clap:
Struggling to find the user ID for rack,can only go back 60 days on purchases on E-Bay,unless anyone knows how to get info from further back????????????? :top: :) |
:top: excellent
will have to do mine like that now .... :content:
:top: :top: :top: |
Think I may have done those TCA's, depending on which batch they were from ;) :DD:
Looking good Kev, keep up the good work mate :clap: :top:
Thanks :cool:
Back axle/susp deffo coming off for the same treatment too :top:
:top: |
Thanks :cool:
Back axle/susp deffo coming off for the same treatment too :top: :top: |
:cool: :cool: :cool:
Thanks :cool:
Back axle/susp deffo coming off for the same treatment too :top: :top: Springs are red allready,do beam red,arms silver,anti-roll bar red,drive shafts silver,diff mount red,diff silver :top: What colours you doin yours m8?????????? :) |
Got the back beam/suspension off,won't look like this for long :cool:
2 hours it took on my own,well chuffed nothin seized or broke!!!!!! :banana: https://img.photobucket.com/albums/v...r/100_0166.jpg :top: |
good work kev :top: ,keep plodding on mate
Still plodding on :DD:
https://img.photobucket.com/albums/v...o-0003_000.jpg Parts ready for shot blast/powdercoating :cool: https://img.photobucket.com/albums/v...r/100_0171.jpg https://img.photobucket.com/albums/v...r/100_0161.jpg Pics of it all powdercoated will be up later next week :) |
:clap: :clap: :clap: :clap:
Very nice work m8. :top:
:cool: looks like youve been busy kev :banana:
Been hard at it with the scrapper/wire brush :cry:
All surface rust taken back to bare metal and treated with rust killer,primed with red oxide,then sealed up any seams that looked like they would hold moisture: https://img.photobucket.com/albums/v...3/100_0200.jpg Then given a good coat of stone-chip ready for the top coat tomorrow: https://img.photobucket.com/albums/v...3/100_0201.jpg Not goin for concours :roll: but nice solid and body coloured :) |
Looking good Kev!! :top:
CosKev3
Hi there. I am really liking the work you are doing on your motor. I have just acquired an Escort GTI as a project and the first thing I want to do is get it up on stands and overhaul the body work including the underneith. Seeing as you are currently doing yours, I was hoping you could tell me what you should put on the underside of the car once you have striped it back to the metal? Is it just a case of applying rust killer, primer, and then top coat? Any advice would be appreciated. Cheers Dan :cool: |
nice work kev :top: bet it took you ages :cry: wont be long now and it will be pukka :top:
Thanks :top:
Hard work,but worth it in the end :)
Originally Posted by DansterST
CosKev3
Hi there. I am really liking the work you are doing on your motor. I have just acquired an Escort GTI as a project and the first thing I want to do is get it up on stands and overhaul the body work including the underneith. Seeing as you are currently doing yours, I was hoping you could tell me what you should put on the underside of the car once you have striped it back to the metal? Is it just a case of applying rust killer, primer, and then top coat? Any advice would be appreciated. Cheers Dan :cool: The more layers/coats you use the better I would think,obviously any rust needs rubbing down/treating. I only use my car for 6 months over the summer,don't think I would bother going to the trouble of doing underside if I used it all year round :roll: Would probably treat the rust and just use underbody sealer/wax oil etc if using through the winter ;) Good luck with yours,get some pics up of the progress :top: |
Top work mate!
Picked up suspension from the powdercoaters :cool:
https://img.photobucket.com/albums/v...r/100_0212.jpg Put first coat of gloss on floor :D https://img.photobucket.com/albums/v...r/100_0215.jpg Coming on well,real pleased I've done it now :content: :top: |
Looks smart! Quality colour choice aswell! :top:
Just make sure you don't scratch it getting the bushes in now :cry: :cry: :cry: I found the ARB link rods the hardest to get back on without damaging :wall: |
top work there m8 keep it up! :clap: :top:
IS that blue or silver Kev :?
Gonna look good when finished :clap: :top: |
That underside looks mint.
Thanks all :top:
Gonna look good when finished :clap: :top: Driveshafts look correct colour,must be the camera/flash :top: |
Just make sure you don't scratch it getting the bushes in now :cry: :cry: :cry: I found the ARB link rods the hardest to get back on without damaging :wall: Yeah,the ARB bushes look tight :cry: How did you do it??????Big 'G' clamp????? :) |
Plenty of lubricant.
The way i found the easiest was to put the ARB up with the brackets and bushes, then try and fit the Links. I think i Covered the jaws of my water pump pliers in masking tape, then used those on them. Not too hard :top: |
The way i found the easiest was to put the ARB up with the brackets and bushes, then try and fit the Links. I think i Covered the jaws of my water pump pliers in masking tape, then used those on them. Not too hard :top: Just got to put them onto trailing arms now when on the car :) |
nice one kev looking minty mint now is your car in a big ass barn ? if so lucky man i hate working on a wet drive :cry:
© 2024 MH Sub I, LLC dba Internet Brands
