My ZVH project.......
Hi guys, I want to share some of the pictures from my Escort Mk4 project.
At this stage I'm not working on the car itself but restorating all the bits and pieces that will be mounted onto it. When everything is ready to bolt on then the shell will be stripped and repainted. Please let me know what you think of the work I've done untill now. Allright, here it comes.......... This picture is one of the front legs with the brake mounted. It's a Sachs shock with an AP spring. The discs are 283mm. Cossie but I'm using the S2 calipers. Off course EBC Greenstuff pads! (I love those) [img]ftp://gast@81.68.229.73/Veerpoot+voorrem001.jpg[/img] This picture shows the rear hubs with the rear brakes mounted. Brakes are Sierra XR4x4 size. (253mm.) [img]ftp://gast@81.68.229.73/Achterfusees+remmen002.jpg[/img] Next 2 pictures are the rear springs and the little item that allows height adjustment. This item (don't know an English word for it) has to be mounted on the chassis rail. Spring has to be shortened until it is as high or low as you want it. [img]ftp://gast@81.68.229.73/Ophanging%20achter001.jpg[/img] [img]ftp://gast@81.68.229.73/Ophanging%20achter002.jpg[/img] And now a picture of the rear Koni's I've resprayed. They are 60mm. shortened items so there will be no chance for the spring to come loose when the car is off the wheels. (that would be APK failure (APK is Dutch MOT)) [img]ftp://gast@81.68.229.73/Schokdempers%20achter/001.jpg[/img] Here a picture of the cilinder head. Standard ERST S2 head but at the moment I'm waiting for a Kent CVH34 kit and a vernier pulley. [img]ftp://gast@81.68.229.73/Cilinderkop/004.jpg[/img] And the block itself..... A 2.0 Zetec, all conversions for ZVH are allready made. Just an experiment, let's see how it will turn out. By the way, this will be the first ZVH Turbo in the Netherlands. There are two other ZVH's but there both normally aspirated ones! [img]ftp://gast@81.68.229.73/ZVH%20Onderblok/ZVH_002.jpg[/img] [img]ftp://gast@81.68.229.73/ZVH%20Onderblok/ZVH_001.jpg[/img] Now some cosmetic shit........ My rear bumper, I filled the space where that strips normally comes in with glasfiber. [img]ftp://gast@81.68.229.73/Achterbumper/018.jpg[/img] And my computer designed speedo............. I left all the little stripes and numbers white and painted the needles with "glow in the dark" paint. When the built in black light goes on, the white surfaces and the green needles will light up. Oh yeah, there is XR3i on it because the car is actually a XR3i..... The looks will stay XR3i but then with a ZVH Turbo in it....... [img]ftp://gast@81.68.229.73/Tellerunit/004.jpg[/img] I'm going to use a RS1600i inlet manifold. Off course with the ERST throttle body fitted..... [img]ftp://gast@81.68.229.73/RSi%20inlaat/004.jpg[/img] A sand blasted gearbox housing. It will become a ERST S2 gearbox with all the bearings replaced. The main bearing (the one that always goes bad) will be replaced for an upgraded item......... [img]ftp://gast@81.68.229.73/Versnellingsbak001.jpg[/img] And last but not least an overview of the "mess" my parents have to cope with......... (there's lots more but it's out of sight!! [img]ftp://gast@81.68.229.73/Diversen001.jpg[/img] Pleae note that the pictures are a bit large and take a while to load. But hey, at least you can see it properly!! :top: Also I must say that I'm hosting the pic's on my own computer so at night when my system is shut down you won't see the pictures. When you don't see them, just come back at a different time and they'll be there. Cheers from the Netherlands, Mark |
none of the picutres work for me mate? :oops:
Very cool mate, any pictures of the actual car tho ? :top: :top: :top:
@Gareth T, the pic's are hosted on my own computer. If the pic's didn't work then my computer was offline...........
@blackRS, here's a picture of the car. Still on the road tho......... Will be stripped when most of the parts are ready. http://home.wanadoo.nl/markvr/xr3i.jpg |
brilliant stuff mate :top: :top: :top: :top: :top: :top: :top:
What managment are you going to use on your ZVH? Looks good, especially the height adjustment for the rear! :top: :clap:
Hi Rab,
For a start I'm going to use the standard KE-Jetronic system for the ZVH. Not aiming for HUGE amounts of BHP's but made a 2.0 for the extra torque coz with a 1.6 you're always "waiting" for the turbo to kick in. I'm hoping to get an engine that's already fast and the turbo on it for that extra shot of power. Just see it as a solution to make the "lagtime" more fun..... :DD: If the Jetronic system turns out to be really shit on a 2.0 then I think it will be time for me to experiment a bit with the Megasquirt system. As for the height adjustment for the rear, that system is designed by an Escort freak from Germany..... They call that guy "professor fützemann"! (don't know exactly what fützemann means tho) He's seems to be the man who knows everything about suspension stuff. :clap: Cheers, Mark |
It might be best to host the pictures at www.photobucket.com so when your computer is offline, everyone can see em :top:
Also, some people may not have FTP access :( |
Hi Fordnatics,
Here are some new pics of my project, let me know what you think of it! :content: https://img.photobucket.com/albums/v...rkxr3i/001.jpg This is my rear bumper with the strip removed. https://img.photobucket.com/albums/v...rkxr3i/002.jpg Metering unit looks good again after some cleaning... :top: https://img.photobucket.com/albums/v...rkxr3i/003.jpg The half-cage for in the car. Thanks to a friend of mine for building it. https://img.photobucket.com/albums/v...rkxr3i/004.jpg How the car looks like now. A lot of stuff came out of there..... Behind it is my Mk2 which is my daily car. https://img.photobucket.com/albums/v...rkxr3i/006.jpg The clutch that has to handle the power. https://img.photobucket.com/albums/v...rkxr3i/007.jpg Of course a GRS jobbie for low ACT's.... https://img.photobucket.com/albums/v...rkxr3i/008.jpg And a GRS alu rad for keeping the water temps low as well! https://img.photobucket.com/albums/v...rkxr3i/010.jpg Old becomes new again....... :DD: Top adjustable Koni's 6cm. shortened! https://img.photobucket.com/albums/v...rkxr3i/011.jpg A second hand scorpion. Took me HOURS to polish it!!!! (no I don't have a girlfriend :? ) https://img.photobucket.com/albums/v...rkxr3i/012.jpg This is how the boot looks like since half a week. Spraypainted it myself. https://img.photobucket.com/albums/v...rkxr3i/013.jpg And another one. This is also the colour the whole car will be when it's ready. It's "Phoenix Gelb" from the E46 M3. Not a Ford colour unfortunately but I fell in love with that colour the first time I saw it. https://img.photobucket.com/albums/v...rkxr3i/014.jpg Boost it up!!! https://img.photobucket.com/albums/v...rkxr3i/015.jpg Same job done as with the rear bumpie. https://img.photobucket.com/albums/v...rkxr3i/016.jpg A front brake.... All mounted on the strut. Off course all wheel bearings are new. https://img.photobucket.com/albums/v...rkxr3i/017.jpg Homebuild 2.0 ZVH turbo engine..... (almost ready) https://img.photobucket.com/albums/v...rkxr3i/018.jpg :banana: :banana: https://img.photobucket.com/albums/v...rkxr3i/019.jpg A nice RS1600i cam cover on a turbo..... https://img.photobucket.com/albums/v...rkxr3i/020.jpg Front strut. Next thing for me to do is strip the car further, throw the 3i engine out and clean out the engine bay. Then the car can go to the spray painter who's going to paint the outside and engine bay for me. After that it's building time and I hope I have the car running and MOT'd before summer. When it will be completely finished I can't tell. Cars like this are never totally finished I guess........ :roll: It's not a complete concours kind of restoration but for Dutch standards it's a big project. Hope you liked to see my pictures, just tell me what you think about it. Cheers, Mark |
Hey Mark, nice to see some progress again. Allthough i'm not too sure about that colour :?
Are you gonna do the underside as well? I think you owe it to your polished exhaust ;) Otherwise it's all coming along nicely i would say. I just love that engine, looks like i have to come by soon to exchange it with mine :p Keep up the good work m8 :clap: :top: |
That looks awesome ,going to look very nice when done,i am a big fan of that colour. :top: :top: :top: :top: :top: :top: :top:
looking good matey :top:
Niet te mooi maken he Mark :D :D
cheeRS Jurgen |
i like the fact ur using a 3i inlet :top:
yip. y dont more people use the 3i inlet? its much neater and tidier than the rst inlet
In fact it isn't a 3i inlet but one from the RS1600i.
The throttle housing from the ERST bolts straight on to the RS1600i one but not to the 3i one. Also the RSi one is totally in one line (see picture) and with the 3i inlet the throttle housing is bolted on at an angle which makes it more difficult to make a cross over pipe from intercooler to throttle body.... :cool: https://img.photobucket.com/albums/v...rkxr3i/021.jpg |
looks good mate :top: :top:
still looks good! :banana:
very nice work i like the adjustable rear springs good idea i havent seen those over here cant wait to see the progress :top:
Just love the work ure doing on the car.
Whish i could get a space to strip my car down, unfortunately i have to do everything on the driveway (weather over here is like in England :wall: ). And the car stil has a lot of work, 1st of all i will get the zetec in and running... Well, Mark... Know the stuff is in good hands, unfortunately i can't make it to the meeting on Sunday so, see ya later. |
looking pretty good mate... but what did you paint your exhaust manifold wit??? |
Just normal heat "resistant" paint. I'm afraid it will come come of the first time the boost gauge will point above 1psi..... :wall: :wall:
It's worth a try and hey, it sure looked nice for the picture... :cry: :cry: |
Hey Mark,
Nice job you are doing there!! So the white is going to be removed?? Good choice :blabla: Greets, Willem |
Hey Willem,
Yes, the white is going. I was in a doubt for a long time. Rebuilt it in white or in this particular colour. "Phoenix gelb" has won! But surely there will be another Ford in diamond white in the future.... I'm dreaming of a Sierra XR4i for a daily driver and that car has to be painted in diamond white!!! But first I need to bring this project to a good end..... :banana: Last news is I've pulled the old lump out of the car. Now the challenge will be getting rid of all the greasy shit onder that bonnet........ :roll: https://img.photobucket.com/albums/v...rkxr3i/022.jpg |
that is a mess good luck cleaning thats the worst bit but it will be worth it :top:
Good luck with your XR, it's going to be a nice car m8!! :top: :clap: |
what front coilover set up is that and where did you get them from
nice project going on there :cool: |
what front coilover set up is that and where did you get them from Bought the dampers from the friend of a friend of mine. :cool: Don't know if these are still available..... :??: |
looking good, looking good :top: :top: :cool:
Finally some real progress in project xr ;) :content: Cheers, |
keep the piccys coming mate :top:
looks good m8 :top: :top:
Long time no update cuz of being too busy with work and education.
But there is progress. The whole car is sprayed with primer and filler and the engine bay is already painted in the right colour! Monday the bodywork will be sprayed... :top: :top: Just a couple of pic's for now..................... https://img.photobucket.com/albums/v...rkxr3i/023.jpg https://img.photobucket.com/albums/v...rkxr3i/024.jpg https://img.photobucket.com/albums/v...rkxr3i/025.jpg |
Looking good Mark!! Will you spray the botom and wheelarches too???
Nice!! :top: :top: :top: :top:
:top:
Well, VERY long time no update. Been kind of busy, met a girl who stole my hart, bought a house, finished my study (and starting a new one in January) and did lots of other things that kept me away from my project.
Finally I'm back to business. The car has been painted in March 2005 and I'm busy in the building proces. Here some piccies...... https://img.photobucket.com/albums/v...rkxr3i/026.jpg https://img.photobucket.com/albums/v...rkxr3i/027.jpg https://img.photobucket.com/albums/v...rkxr3i/028.jpg Here the car just rolled out of the spray painters workspace.... :top: Cheers...... |
thats a lovely colour mate !!!!
The colour is awesome!
:top: :top: :top: |
is there pics of this car finished?
No unfortunately not. Car is not finished yet. But here are some more pictures of the building proces. :banana: https://img.photobucket.com/albums/v...xr3i/005-1.jpg https://img.photobucket.com/albums/v...xr3i/006-1.jpg https://img.photobucket.com/albums/v...xr3i/008-1.jpg https://img.photobucket.com/albums/v...xr3i/016-1.jpg https://img.photobucket.com/albums/v...xr3i/018-1.jpg https://img.photobucket.com/albums/v...emcilinder.jpg https://img.photobucket.com/albums/v...rruimte004.jpg https://img.photobucket.com/albums/v...ngvoor_005.jpg Cheers.... |
© 2024 MH Sub I, LLC dba Internet Brands
